check engine light
sup, here's the question..
i have a 92 accord 5spd i just changed the clutch and bled the clutch car drives fine but just the other day while driving the check engine light came on...
I dunno why was that every thing works fine... what could be causing the light to come on...
Modified by true-elements at 7:36 AM 5/29/2008
If you retrieve the codes from the ECU they will tell you why the CEL is on. If you are unsure of how to retrieve the DTCodes yourself. There is a paper clip method that you can use.
3 Easy to Follow Steps:
1.) Locate the blue 2 pin jumper plug. It is attached to a metal support under the glove box
2.) WITH THE CAR OFF, insert either a 2pin connector clip, paper clip, or loop a thin enough piece of wire into both holes on the connector.
3.) Back in the driver's seat, turn the key to the 'ON' position. The CEL light will come on at startup, like normal, but it will then begin to flash.
**By counting the number of flashes, you can decipher the CEL #.
SHORT flashes are single digits (1/2 second)
LONG flashes are 10's (1 second)
Ex
short...short...short = code 3
short...short...long...long...long = code 24
Ex
I do not want to seem rude, however I wanted to interject this information;
The service check connector [Blue 2 pin] is located just behind the top of the passenger side kick panel on the 90-93 Accords. It was taped to the wire harness at the factory with Blue tape.
In 94 Honda moved it to a holder behind the glove box, yet still in the area of the top of the kick panel.
Well I am about as rude as they come
short...short...Long....Long...Long =24? WTF?
Hey Ghost roll up one for me LMAO.
Here is a link for most of the Honda OBD 1 codes;
http://www.troublecodes.net/honda/hondadtc.shtml
No man your not rude your an American.....lol.....
phhhhhhhhht........phhhhhhhhhhtttt.......phhhhhhht tt..... cough cough......"in choked up voice" Well Up here in Canada phhhhhhhhttt......phhhhhhhttt.....phhhhttttt...... we like to think free. Pot is not the gateway drug to pure evil. phhhhhhhhttt......phhhhhhhttt.....phhhhttttt...... We are not dictated buy some **** retentive left wing war monger, unshaven ***** bush gov't..... phhhhhhhhttt......phhhhhhhttt.....phhhhttttt...... "hold on man I'm almost done here" phhhhhhhhttt......phhhhhhhttt.....phhhhttttt...... Any time your north of the boarder, on the east coast, look me up & I'll roll up a big fat gagger for ya free of charge.
2+2 is 3, 2+2 is 3 "Homer Simpson Voice"
Modified by GhostAccord at 10:41 PM 5/29/2008
nguyennhatquang
Nov 16, 2005 02:32 AM
