type r suspension question??
Old May 29, 2008 | 05:20 AM
acurar's Avatar
Default type r suspension question??
Ok so I need some help!
I have an 01 type r that has neuspeed springs and that is it for the suspension.
I found some tein coilovers for a DC and I want to use these on my type R, is the rear lower control arm the only thing I would have to swap out to make these fit?
Is is worth it to put htese on my R?
Then I want to take the old Neuspeed Springs and put them on my daily a 2000 civic Ex 2dr. Will that work? Can I put the whole type r strut assembly on my civic with the neuspeed springs??
Thanks and a pic of my R just because
Old May 29, 2008 | 05:26 AM
davidnyc's Avatar
Default Re: type r suspension question?? (acurar)
What are the spring rates?
I believe it would be better to change the shock body to fit the R lower control arms as opposed to going with GSR lca. I think the R lca's are "stronger/stiffer" than GSR lca's, but I could be wrong.
I think the swap of the springs should be no problem as long as the length and diameter match.
Old May 29, 2008 | 05:27 AM
jgirard's Avatar
I would skip on the teins and get PIC coilovers that are ITR specific
Old May 29, 2008 | 05:29 AM
acurar's Avatar
what if you were getting a really good deal on the teins
Old May 29, 2008 | 05:32 AM
davidnyc's Avatar
Default Re: (acurar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurar &raquo;</TD></TR><TR><TD CLASS="quote">what if you were getting a really good deal on the teins
Suspension and transform a car to being something great or something really crappy.
If I were you.... buy the Teins, put them up on Ebay and use the money to get PIC's.
Old May 29, 2008 | 05:33 AM
acurar's Avatar
could i just get stronger aftermarket lca for a gsr
Old May 29, 2008 | 05:35 AM
acurar's Avatar
how much do pic run
Old May 29, 2008 | 06:35 AM
get RIGHT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurar &raquo;</TD></TR><TR><TD CLASS="quote">how much do pic run</TD></TR></TABLE>
http://picperformance.com/store/scripts/news.asp
Old May 29, 2008 | 06:56 AM
Erik95LS's Avatar
regardless of what you decide I would definitely keep the R LCAs on the R.
Old May 29, 2008 | 07:10 AM
jomama's Avatar
Default Re: (davidnyc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidnyc &raquo;</TD></TR><TR><TD CLASS="quote">
If I were you.... buy the Teins, put them up on Ebay and use the money to get PIC's.</TD></TR></TABLE>
absolutely... as long as the guy you're buying the teins from wouldn't mind or whatever why downgrade to GSR parts?
Old May 29, 2008 | 07:14 AM
acurar's Avatar
yeah i agree with you guys(why take type r parts off)
type-GGSR
May 19, 2008 08:00 AM
Type ARRR
Feb 17, 2008 01:38 PM
josh combs
Sep 10, 2007 12:24 PM
primetime
Jan 1, 2007 08:22 PM
jxkim89
Suspension & Brakes
Oct 12, 2006 05:28 PM
