short ram back to stock intake...need help and advice
hey guys, when i first got the car i replaced the stock air box with a short ram. I was thinking about going back to the air box though and just putting in a k&n filter. Currently the one I have is a piece of junk no name filter.
First of all, do you think it would be a good idea to go back to the stock air box and just drop in a k&n? Or do you think I should leave the no name short ram and just throw a cone k&n filter?
Also, I had already tried to put the air box on, but had a problem. There is a sensor and vacuum that come off the intake right by the throttle body. The vacuum goes to the valve cover. I need a picture of what that looks like all hooked up, because for some reason, its not fitting right for me.
This is a picture I had before putting on the short ram, and you can see i just barely left out the area of concern.
If someone could just provide a picture of the intake by the throttle body and the vacuum that goes to the valve cover, I would really appreciate it! thanks
piggs
10
Jan 8, 2004 09:12 AM
