how bad is it to run with a colder thermo
Old May 28, 2008 | 11:00 PM
Hanmin's Avatar
Default how bad is it to run with a colder thermo
I bought a colder thermo I heard running a colder engine gives you more power? How could using the colder thermostat(160deg) hurt my engine? or anything else?
Old May 29, 2008 | 01:41 AM
EKstacy's Avatar
Default Re: how bad is it to run with a colder thermo (Hanmin)
It wont hurt your engine, but i dont see it giving you any more power either.
Old May 29, 2008 | 02:40 AM
2004es2's Avatar
If your engine runs colder than it should I heard your oil turns into sludge faster. As for gaining power, a slightly lower temp. will make it run more efficiently but you wont see much of a gain unless you plan on doing an endurance race.
Old May 29, 2008 | 02:04 PM
Hanmin's Avatar
what about gas mileage? and doesnt a colder engine help prevent detonation?
Old May 29, 2008 | 02:07 PM
OMGWTFBBQ!'s Avatar
Honda engines already run cold from the factory, you're not helping anything if you dont have a massively modified engine. I would stick with an OE thermostat myself.
Old May 29, 2008 | 02:32 PM
Hanmin's Avatar
180 is the normal temp. I just want to know what all could happen by running a colder thermo. I want to put it in because my car wants to rev limit at 3.5k only when its warmed up. So I thought I could lower the temperature permanently to fix the problem. I don't care about this motor, if it blows it blows, but I don't want it to keep restricting me at 3.5 every now and then. I'm just gunna throw the thermostat in. Any more information on what running on a colder engine can cause. Is it bad to start your car in the cold and just start racing right away? what can happen?
Old May 29, 2008 | 02:43 PM
OMGWTFBBQ!'s Avatar
You could blow your engine by beating on it cold, but you probaby won't. Your engine shouldn't lower your rev limit to 3.5k, and getting a colder thermostat won't stop that anyway. Your ecu has a coolant temperature check, which should only stop you from going into VTEC like mine does.
Old May 29, 2008 | 03:03 PM
Hanmin's Avatar
My engine likes to rev limit when its warmed up and when im pushing it, it doesnt do it when its cold and im pushing it. It goes in to limp mode or something with no cel. A colder thermostat= colder coolant going through the engine= colder engine. I dont have vtec hooked up so i dont care if the engine isnt warm enough for vtec.
gtimax
Aug 29, 2011 05:00 PM
LL_SP4RROW
Jun 3, 2011 10:00 AM
petrv
Jan 12, 2006 11:03 PM
b20integrapower
Jan 1, 2006 09:47 PM
KooK
Mar 29, 2002 08:27 PM
