fuel or ignition problem?? 92 civic w/ls motor
Old May 28, 2008 | 08:57 PM
RacinMasonC's Avatar
Default fuel or ignition problem?? 92 civic w/ls motor
hey guys just seeing if anyone knows whats up with my car? i'm stumped.. car is a 92 civic with ls swap in it using the pr4 ecu. Car sputters like its misfiring like crazy sometimes driving or taking off from a start, and yes it has no power at this time, pulled the plugs and they are looking a little lean so i richened up the AFC to +20% even and it has a hint of it getting a little richer.. i have stock injectors, rails, pump.. has new cap, rotor, plugs, wires, fuel filter, fuel pressure reg, o2 sensor.. it's bugging me and it just started this!! when the car is under more load it runs like a top! just under crusing throttle or getting up to speed it sounds like its misfiring then it drives normal, its a continous cycle. pulled the codes and all it comes up with is code 3 which is the map sensor only cuz the AFC taps into that wire. i'm lost and just need some more help!!!
RobertoHdz
23
Nov 12, 2018 06:58 AM
1SlowSiHB
Dec 21, 2009 04:47 AM
davcataa
Oct 26, 2009 10:41 PM
RacinMasonC
May 28, 2008 09:21 PM
theEGkid
Jul 28, 2006 07:48 AM
