Are all d series ac compressors the same
Old May 28, 2008 | 06:05 PM
averyvm's Avatar
Default Are all d series ac compressors the same
As stated in topic I was wondering if all d series ac compressors are the same. Someone is selling a 96 ac compressor and I was wondering if it would fit on my 93 hatch
Old May 28, 2008 | 09:07 PM
jdmeg6118's Avatar
Default Re: Are all d series ac compressors the same (averyvm)
I put an AC compressor form a 94Ex into a 2000 civic i i would say yes
But im not sure if 93 had the upgraded freon
Old May 28, 2008 | 09:16 PM
nskforlife's Avatar
it shouldnt matter as long as you recharge your kit. from what i've heard r134 takes more energy to cool than r12, so a compressor designed for r134 might have a slight cooling advantage.
Old May 28, 2008 | 09:23 PM
superfast666's Avatar
Default Re: Are all d series ac compressors the same (nskforlife)
there both wrong 92-93 is different from 94+
Old May 28, 2008 | 09:37 PM
nskforlife's Avatar
Default Re: Are all d series ac compressors the same (superfast666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superfast666 &raquo;</TD></TR><TR><TD CLASS="quote">there both wrong 92-93 is different from 94+</TD></TR></TABLE>
but do they mechanically fit and function.
Old May 29, 2008 | 05:26 AM
averyvm's Avatar
the reason I ask is because I want to put a 96 d16 compressor into a 93 EG. the system is designed for R12 but the compressor takes 134. will it work? bump
Old May 29, 2008 | 06:06 AM
DarkGenesis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by averyvm &raquo;</TD></TR><TR><TD CLASS="quote">the reason I ask is because I want to put a 96 d16 compressor into a 93 EG. the system is designed for R12 but the compressor takes 134. will it work? bump</TD></TR></TABLE>
The compressor doesn't really required a certain type of freon that is in there. The only part that you need to change is the receiver/dryer bottle to either a R134 or an R12 whichever freon you planning to use. This unit is located near the left headlight and has two pipe connects to it and bolted to the chassis.
JohnnyEF
Jun 7, 2012 03:16 AM
akire45
Aug 7, 2009 09:30 AM
Danal976
Jan 9, 2008 04:59 PM
mystikalG
Jul 2, 2007 09:53 AM
