Boosted car not starting Map Sensor
K just wondering if the MAP with prevent a car form starting. I have a 99 gsr turboed. The wires r good, fuel pump works, injectors are getting power, the dizzy is new. The car will turn over but will not fire and the iac will start buzzing. I am using a piggyback computer but im thinkin if that were toast the car would still start but run rich. So im left with not enough fuel pressure of map im thinkin.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akalima »</TD></TR><TR><TD CLASS="quote">K just wondering if the MAP with prevent a car form starting.</TD></TR></TABLE>
No. It will prevent it from idle-ing. Is it throwing a code? Sounds like you have the plugs mixed- I think they are the same (3-pin round)
Yes. the map sensor can make it not start. A buddy of mine had the motorola 2.5bar and somehow one of the legs broke off flush to the sensor. It would not start at all. He disconnected the 2.5bar and hooked up the stock map that was still on the tb and luckily I had a chip with from my previous tune with the same size injectors on the stock map. It fired right up and was able to cruise it home.
I know its not the coil. It happend befor e i changed the dizzy out with a complete unit from distributor king. Ill see if i have continuity on the pins from the map sensor before i spend the bucks on a new one.
