noob question... wat holding engine n tranny
Old May 28, 2008 | 12:56 PM
Civic-Kids's Avatar
Default noob question... wat holding engine n tranny
later on am planning to swap it out. j/w wat holding the engine n tranny... the 2 both on each side (left n right), 2 axle n the pipe under the header to the converter. this is wat i think... is there anything missing...
Old May 28, 2008 | 01:10 PM
blk92_d16's Avatar
Just the mounts and the bunch of bolts holding the mounts onto the frame and subframe.
Old May 28, 2008 | 02:23 PM
Hanmin's Avatar
from the top of my head.
Drain Coolant
Draing engine and tranny oil
undo shift linkage from under the car
remove headers from pipe
remove front suspensions
remove tires
remove axle nut
remove cotter pin
remove castle nut
take the hub off of the Lower control arm???(dont know what its called.)
pull axle off of hub
do this to both sides
get a pry bar and remove the axles from the tranny
remove radiator
remove the 2 heater hoses from the motor to the car
unplug the left and right side of the engine harness
remove clip and unbolt the clutch line
remove throttle cable
bring in w/e your gunna use to pull or drop the motor with.
undo the tranny mount, back bracket, driver mount, and the mount on the ac bracket, and the other one on the tranny if you still have all of those.
Drop/pick up and maneuver it out.
if you got confused on anything there, dont do it or youll be enjoying the bus for awhile
oh; yeah, and some hoses that goes from the IM to the black canister and booster. And the hose that goes to the fuel pressure regulator.
projsectEF
May 22, 2006 08:36 PM
IMSTOCK
Dec 2, 2005 04:46 PM
CRseXy
Nov 22, 2004 08:09 AM
0ptimus prime
Jul 17, 2004 11:17 PM
SICKSOLSI
Dec 22, 2003 02:43 PM
