PM6 ECU HELP!!!!!!
Old May 28, 2008 | 12:09 PM
toolbox21's Avatar
Default PM6 ECU HELP!!!!!!
Ive been looking for a PM6 ECU Pinout, I need one so i can re-wire my buddys IAT Sensor because i dont think its wired up right and i need a pinout so i can wire it right ,and i cant find one anywhere. So if someone has one or finds one let me know?
Thanx
Old May 28, 2008 | 12:38 PM
jlicrx's Avatar
Default Re: PM6 ECU HELP!!!!!! (toolbox21)
IAT sensor wiring - red/yellow wire goes to ECU pin C5 - green/white wire goes to ECU pin C12 (common ground for a lot of the sensors which all come together inside the harness)
Old May 28, 2008 | 12:54 PM
toolbox21's Avatar
Default Re: PM6 ECU HELP!!!!!! (jlicrx)
Tru, alright due thanx, that will help me alot, but what i was wondering was that on my buddy's harness the wires that run to the sensor plug are Black/Yellow, and Blue/Yellow
Old May 28, 2008 | 01:15 PM
jlicrx's Avatar
he has the EACV connector plugged into the IAT sensor - surprised that he isn't also getting code 14 - is the connector green?
if the car was originally DPFI, it should have one connector left over that isn't used - also 2-wire with orange and black/yellow wires
by the way, i asked on his other thread if he had the correct connector plugged in - he said he had it right
Old May 28, 2008 | 02:18 PM
toolbox21's Avatar
yeah its a DX so i was originally a Dual Point, so yeah there are 2 identicle plugs and ones green thats the one that was plugged into the IAT senor i thought it was wrong i wasnt sure because he bought the car like that. so what i need to do is get the other plug (the right one) and run thoes wire to the correct pins on the ecu..??????
Old May 28, 2008 | 02:24 PM
jlicrx's Avatar
what is plugged into the EACV? probably the plug you need
Old May 28, 2008 | 04:02 PM
toolbox21's Avatar
um im not sure ill have to look at it tomorrow. but i know there's 2 identicle plugs on green and one white/clear and we currently have the green one plugged into the IAT sensor and the other one is just hanging(not in use). See i can do engine swaps, suspension, tires, interior, body just about everything but i havent messed with ECU Wiring and Stuff thats one thing i havent master, so your being a great help
Acc3l3ratoR
May 1, 2019 07:41 PM
Batoutahell
Jan 29, 2006 06:45 AM
RaceInspired
Jul 22, 2005 08:27 AM
spoolnbyu
Jun 5, 2005 07:46 PM
AdamITR
Apr 26, 2003 01:28 PM
