2001 F4i Turnsignal and Tail light issues, PICS included
Old May 28, 2008 | 06:21 AM
buddy4002's Avatar
Default 2001 F4i Turnsignal and Tail light issues
Hello all,
Recently picked up a 2001 F4i that has some minor wiring issues. The turn signals do not work and when you select a right turn the emergency flashes come on? The tail light does not work either. I have found this mess of wiring that is probably responsible for all this and was wondering if anybody could give me some input. If someone could take a picture of their current wiring that would help out also.
Thanks
Old May 28, 2008 | 06:28 AM
.RJ's Avatar
.RJ
Default Re: 2001 F4i Turnsignal and Tail light issues (buddy4002)
You need to get a wiring diagram and 'rebuild' that end of the subframe harness, wire by wire. Unfortunately there's no other option or quick fix but its not that bad - there's only a handful of wires to trace back.
Old May 28, 2008 | 06:35 AM
ASteele2's Avatar
Default Re: 2001 F4i Turnsignal and Tail light issues (.RJ)
PM me your email address. I have an F4i wiring diagram that I can email to you when I get home tonight.
Old May 28, 2008 | 06:57 AM
buddy4002's Avatar
pm sent
the wiring that still has the factory connectors on it, did they originally go to the rear turn signals?
EDIT: I found a schematic but need a picture of the factory wiring harness so I can identify the factory wiring harness by color. If someone could snap a picture similar to the ones shown that would help out a ton.
http://sportbikeguy.com/garage...l.pdf
Modified by buddy4002 at 8:07 AM 5/28/2008
Old May 28, 2008 | 08:36 AM
SkRiBLaH's Avatar
Default Re: (buddy4002)
tkae the rear plastic off (makes it much easier)
and it's simple as **** to fix. those connectors (orange blue white) are turn signals and license plate light.
go from there.
Old May 29, 2008 | 11:34 PM
bg-33p's Avatar
Default Re: (SkRiBLaH)
Yeah take off the fairing, about 4 bolts, and you'll have much more space to work.
Old May 30, 2008 | 01:45 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (bg-33p)
i cant tell from your mess of wires, but the 01-03 F4i should have 5 plugs.
2 are for the brake lights. each plug to each bulb should have 3 weires. ground, constant, and brake.
there should be another grey plug, with only 2 wires.. tahts the licence plate light.
for the 4th and 5th plug, should be the orange, and blue tab'ed connectors... those are for the turn signals. each of those should have 2 wires also.
so... you have 5 connections. the turn signals, and lic. light have 2 wires to each. the tail light (2 plugs to each seperate bulb) should have 3. a ground, a running light and a brake light signal.
what you need to do is take that plastic tail off, and physically look at each item. see where the wires from each turn signal come from. follow that wire to the plug.
also.. does your bike have flush mounts, or any type of aftermarket front turns? some times poeple use LED's, which aren't dual filament (running lights & blink) and wire them all together, and mess **** up.
Old May 30, 2008 | 01:48 AM
Built B16A's Avatar
Default Re: (Built B16A)
also, reading your 1st post again.. you siad with the right turn, the emergency flashers come on....... our bikes doesn't have hazard lights. so you must have the a problem where the left and right blinker wires are tapped into each other...
do the turn signal indicators on the gauge's blink both also, or only right... and both lights are on? that would mean a wiring problem.. if both left and right signals are on the gauge.. you bike is possessed.
Old May 30, 2008 | 07:59 AM
93civic_sedan's Avatar
Had to "rebuild" the tail harness on my 929. Its not that bad really. It was a PITA because it was tedious, just take the tail off and re-wire each one...
Old Nov 14, 2021 | 11:03 AM
natethegreat4's Avatar
Can i get a copy
Bobby01
Honda CR-V & Element
Apr 5, 2017 10:30 PM
VTcivicHB
Acura TSX
Jul 15, 2011 09:59 PM
buymesomedunks
Feb 22, 2010 06:33 PM
KaoticSnow
14
Mar 14, 2005 06:05 AM
MTR.18
Jan 18, 2003 01:04 PM
