GSR Rear Brake Swap Issue
ok i just swapped in a 95 GSR rear brake swap in my 97 hatch the brakes seem to be working fine but im having issues with the emergency brake. the passenger side seems fine but the drives appears to be too short. should they just bolt right in or am i going to have to use my old ebrake cables. the gsr cable wont even go as far as the clamp that bolts down on them to hold them in place.
I had to eliminate the center mounting bracket to get mine to reach. Use only the bracket on the trailing arm and the one where it makes the turn into the "tunnel" to hold it in place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicSi »</TD></TR><TR><TD CLASS="quote">I had to eliminate the center mounting bracket to get mine to reach. Use only the bracket on the trailing arm and the one where it makes the turn into the "tunnel" to hold it in place.</TD></TR></TABLE>
I also had to do this in my ek.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fullthrottle297 »</TD></TR><TR><TD CLASS="quote">would it make a difference if i pulled the cables off of my old drum brakes and put them on would they be longer ?</TD></TR></TABLE>
No because the the piece that mounts the e-brake cable to the caliper are different from drum to disc, you'll see.
dck1ng69
Jan 1, 2018 12:57 PM
