GSR Rear Brake Swap Issue
Old 05-28-2008, 04:34 AM
Fullthrottle297's Avatar
Default GSR Rear Brake Swap Issue
ok i just swapped in a 95 GSR rear brake swap in my 97 hatch the brakes seem to be working fine but im having issues with the emergency brake. the passenger side seems fine but the drives appears to be too short. should they just bolt right in or am i going to have to use my old ebrake cables. the gsr cable wont even go as far as the clamp that bolts down on them to hold them in place.
Old 05-28-2008, 05:39 AM
94CivicSi's Avatar
I had to eliminate the center mounting bracket to get mine to reach. Use only the bracket on the trailing arm and the one where it makes the turn into the "tunnel" to hold it in place.
Old 05-28-2008, 08:42 AM
* B A N N E D *
cubanSiR's Avatar
couldnt tell you bro...i swapped my front and rears from a 99-00 SI onto my 97 hatch. I used the SI e-brake lines...everything fit and bolted right up...
Old 05-28-2008, 08:47 AM
spoon978's Avatar
Default Re: (cubanSiR)
i swapped a 95 gsr in my 93 hatch and it was fine same e brake cables(GSR)...
Old 05-28-2008, 09:23 AM
Default Re: (94CivicSi)
would it make a difference if i pulled the cables off of my old drum brakes and put them on would they be longer ?
MilanoRedCoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">I had to eliminate the center mounting bracket to get mine to reach. Use only the bracket on the trailing arm and the one where it makes the turn into the "tunnel" to hold it in place.</TD></TR></TABLE>
I also had to do this in my ek.
Old 05-28-2008, 10:32 AM
riceburnerryan's Avatar
i ran the stock GSR ebrake cables..
Old 05-28-2008, 10:40 AM
EL Vap133's Avatar
Default Re: (Fullthrottle297)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fullthrottle297 &raquo;</TD></TR><TR><TD CLASS="quote">would it make a difference if i pulled the cables off of my old drum brakes and put them on would they be longer ?</TD></TR></TABLE>
No because the the piece that mounts the e-brake cable to the caliper are different from drum to disc, you'll see.
Old 05-28-2008, 10:53 AM
OMGWTFBBQ!'s Avatar
You can't re-use the drum e-brake cables like ^ said. You will have to unbolt some of the securing brackets, I had the same problem with my rear disc swap.
dck1ng69
01-01-2018 12:57 PM
jdp1978
11-14-2009 07:51 PM
silentbeatdown
02-19-2008 01:51 PM
19992civichatch
09-02-2007 09:55 AM
BolivianDc2
08-11-2004 07:40 PM
Quick Reply: GSR Rear Brake Swap Issue
