Urgent Help! (Fuel rail related) EK vti
Old May 28, 2008 | 04:15 AM
vogueVTI's Avatar
Default Urgent Help! (Fuel rail related) EK vti
Hey guys.
Well after receiving my OBX fuel rail I came to fit it. Like a noob I never had a 22mm spanner to tighten the banjo up and used a pair of mould grips. Anyhow, I ended up snapping the stud that goes into the fuel feed on the rail.
I cannot find a replacement stud ANYWHERE, so have came to the conclusion I may be able to use a banjo bolt instead.
Few questions I need answers to...
WTF is this (some sort of restrictor?) and can I get rid of it? :
This is the stud I snapped:
And this is the rail I have:
Can I just simply f*** that thing off that is circled above and use a banjo bolt instead?
Does Anyone know what size banjo bolt I would need to fit an OBX fuel rail? (the thread on the stud is 1/2", but I need to know the height of the banjo??
Cheers guys!
Old May 28, 2008 | 04:47 AM
o0Jash0o's Avatar
Default Re: Urgent Help! (Fuel rail related) EK vti (vogueVTI)
fastenal, they wont have it orginaised my car but if u take a easy out tool and pull the stud out they will either have the stud you need or will make on for u
Old May 28, 2008 | 05:27 AM
sorrule's Avatar
shouldn't you use the banjo bolt anyways? Your are using your stock fuel line right? Well the one you broke doesn't even have a hole for fuel to go in.
Old May 28, 2008 | 06:37 AM
vogueVTI's Avatar
Default Re: (sorrule)
Yeah I know that now lol. Im gonna get a banjo bolt i think.
But what is that in the pic that i have circled? will it run ok if i remove it?
DC4_MADMAN
Apr 17, 2014 12:49 PM
4ghatch
Sep 2, 2005 08:19 PM
shivern
Dec 12, 2004 05:42 PM
EVOCELICA
Nov 11, 2002 05:51 PM
