timing belt tensioner
Old May 28, 2008 | 03:10 AM
SleeperGSR's Avatar
Default timing belt tensioner
What does it sound like when it's going bad??? I think mine is. There is a metalic sounding squeek at rpms from the belt side of the motor. i'm sure i could be a number of things but help narrowing down the list would be good. thanks for any help
Old May 28, 2008 | 07:06 AM
jomama's Avatar
Default Re: timing belt tensioner (SleeperGSR)
not sure what it'd sound like as i've never had one go bad on me but...
*how long ago did you change it?
*how long ago did you change the timing belt and water pump?
*do you always here the sound? what RPMs? constantly or intermittent? in other words, what do you mean by "squeek at rpms?"
*what makes you think it's the tensioner?
Old May 28, 2008 | 09:27 PM
SleeperGSR's Avatar
Default Re: timing belt tensioner (jomama)
still the origonal timing belt at 103k changing next week.
Water pump will be changed too at that time.
I only hear the sound at lower rpms under 3k and it seems to be in time with the rpms also(if the rpms drop the squeek slowes down
the only reason i thought it was the tensioner is that i've read that they will make a noise when they start to go bad, and i don't know what it would sound like. And i figured while i was in there i might as well change it too?
Any other thoughts or opinions???
Old May 29, 2008 | 07:36 AM
jomama's Avatar
^good to hear you're changing all of that. just go from there and see if the sounds still around afterwards. GL.
Old May 29, 2008 | 07:47 AM
dplatt's Avatar
Default Re: (jomama)
It can squeak, or sometimes it will make a slight "rod type" knocking noise.
Old May 29, 2008 | 12:51 PM
SleeperGSR's Avatar
Default Re: (dplatt)
Thanks for the help everyone. It's definatly not a knocking noise. Well it looks like i'm just going to have to fix what i can and see if it's still around. I guess it could be comming from any of the pullys. Does the alternator start to make a noise when it is about to give up???
Old May 29, 2008 | 03:27 PM
dplatt's Avatar
I would remove all of your accessory belts (including the alternator) one at a time starting the car between each belt removal and see if the sound goes away. If it never goes away that takes the alternator, AC, and PS out of the solution tree.
vbolz
Apr 11, 2011 09:13 PM
ham
Aug 2, 2005 05:17 PM
salvageland
Oct 29, 2004 03:10 PM
Bobby
Nov 25, 2002 08:42 AM
PapaPark
13
Dec 16, 2001 12:46 PM
