oil consumption
Old Jul 15, 2002 | 10:08 PM
Malgerus's Avatar
Default oil consumption
Well, I went to the track with the dipstick reading completely full. I made 8 passes, drove home and sat on my ***. Next day, I checked the oil and it was a litte bit lower. Not drastically lower or anyting like that, maybe one eigth down or so. Is this normal?? Did a compression test, reads 213-217 across the motor, plus there is no blue smoke at all. Just a little bit of whitish smoke, but not the antifreeze type of smoke. I filled it up this morning and check it after 10 miles or so, and it was the same. Am I just being paranoid?
Old Jul 16, 2002 | 07:13 AM
PatEJ6's Avatar
Default Re: oil consumption (89_Y_49)
I put a pint every time I fill up the gas tank, so don't worry
Old Jul 16, 2002 | 12:09 PM
Malgerus's Avatar
Default Re: oil consumption (SpeedyPat)
Whoa! Are you blowing blue smoke??? I just checked the oil this morning and it's in the middle of the full hole.
Old Feb 10, 2003 | 08:23 AM
blackludeH22's Avatar
Default Re: oil consumption (Mr. S)
I have a new rebuilt motor and I burn a little less than half a quart every 40 miles or so. It's blowing blue smoke, when I pull the car out of my garage after it's warmed up the blue smoke would clog the street, then it stops a min later.
[Modified by blackludeH22, 5:24 PM 2/10/2003]
Old Feb 10, 2003 | 08:50 AM
keithv's Avatar
Default Re: oil consumption (blackludeH22)
mr. s, what motor are you running?
fyi, vtec motors are notorious for burning oil, esp. synthetic...
Old Feb 13, 2003 | 05:50 PM
Malgerus's Avatar
Default Re: oil consumption (breaka_1_9)
heh. Old thread. I was running a D16Y8... I never had that problem again. Kinda weird, huh? It never burned oil up until I smashed it
Old Feb 13, 2003 | 06:35 PM
USDM 4G VTEC's Avatar
yeah i was wondering about that
my engine burns like a 1/4 qt every 500-1000 miles
theres no visible oil leak, besides the valve cover striped bolt that cryies, no burn oil... pistons rings, seals and everything its new when rebuilded, when i took head off none vavle seals where leaking, no bad headgasket, cylinders are good .. it just consumes alil... and i tought i had a problem
Old Feb 13, 2003 | 07:09 PM
grasshopper's Avatar
A compression won't necessarily mean you aren't burning oil. You should do a leak down test and check your valve seals.
Old Feb 13, 2003 | 07:22 PM
TRE_'s Avatar
Default Re: oil consumption (grasshopper)
my cousin, who works at bell acura in phoenix said that VTEC motors are known for burning a little oil(as breaka said). the new nissan spec v's have a problem with burning oil because thier variable valve timing is similar to vtec. i have heard of a few people driving the poo out of their spec v's, burning all the oil and the engine goes dead. i guess its happen quite a few times. anyway, i wouldnt worry about a little minor oil consumption; its just your vteckhc!
Old Feb 14, 2003 | 06:26 AM
PatEJ6's Avatar
Default Re: oil consumption (glowing_rotors)
Jebus that's some old thread I should reply since you asked me a question hehe, better late than never
I was actually, since I sold my crx in august last year, but yeah I was blowing blue smoke like you wouldn't beleive it. I was in crxmtl club at that time (www.crxmtl.com) and everyone was complaining about the smell when we were riding hehhe, so often I had to go last .
I'm glad I sold it, I love my Ek now
Old Feb 14, 2003 | 10:57 AM
Ef Whore's Avatar
Default Re: oil consumption (PatEJ6)
Keep in mind 8 passes down the 1320 at full throttle is beating the motor, so yeah it's gonna burn a little oil.
Old Feb 14, 2003 | 01:14 PM
Outsane's Avatar
were you on leval ground each time....
next time check your oil in the same spot twice a couple of weeks apart just to be sure
Old Feb 14, 2003 | 01:18 PM
Malgerus's Avatar
Default Re: oil consumption (Outsane)
Well, it was weird cuz I filled it, and then it never went down again, even after going to the track again. Plus my brothers B16's oil level never goes down, even after a day at the track [shrugs]
Old Feb 18, 2003 | 08:39 AM
ejprimo's Avatar
i burned a little bit of oil using mobil 1 5w-30 so i switched to mobil 1 10w-30 and havent burned any oil yet.
bambbrose
Nov 21, 2007 06:39 PM
Lucky-13
Jan 31, 2007 05:21 PM
Layziebtnh055
Apr 18, 2004 11:45 AM
redteg1
Sep 19, 2002 04:29 PM
92HB_HB
May 5, 2002 06:24 PM
