Sandblast/Powdercoat
An friend and I are gonna buy a sandblaster and a powder coating kit. Im thinkin about doin some wheels I have layin around. Can anyone tell what would be better! sandblast then coat or chemical strip then coat. I have 3 sets of wheels I wanna do! The sandblastin kit is the one that uses play sand. Thoughts, Flame, really good info.
1 set Rota Grind's
1 set Enkei Zoku's
1 set GSR Blades
1 set Rota Grind's
1 set Enkei Zoku's
1 set GSR Blades
false, i use 70 Grit Aluminum Oxide and doesn't pit the metal at all, and i've done several wheels... it's the coarser grit that causes it... to answer the OP, yes. sandblast then coat them.
I don't think they use sand for blasting anymore. I think they call it "media blasting" now, and they use less abrasive stuff to do the blasting.
The toughest part is going to be finding an oven large enough to hold the wheel after you have done the powdercoating. The media blasting and powder coating itself should not be a problem.
If I were you I would probably pay a professional to do the whole job for you. The amount of money you will spend for the media blasting and powdercoating equipment will probably cost more than the cost of having it professionally done.
It can be tough to find a skilled powder coater. You have to ask around and see if anyone knows anyone in your area that they recommend.
I dont know what professional's you have around where you live but I know people that have spent $800 or more for that and I can get all the stuff for like $400. Thanks for the info just the same
blades, blasting, charlottesville, chicago, coat, gsr, honda, media, powder, powdercoat, sandblasr, sandblast, sandblaster, tech, wheels
