b16 is in....cylinders #2 and #4 getting no spark
Old Jul 15, 2002 | 09:47 PM
red civic standard's Avatar
Default b16 is in....cylinders #2 and #4 getting no spark
just installed a b16 into my 91 civic standard.
starts fine, idles fine, but is bogging heavy under 5000 rpms...so i pull the plugs to look at them and cylinder #2 and #4 are super black...so black that they are getting no spark (i checked with the timing light).
so i clean off the plugs and throw them back in...cylinder #2 and #4 fire correctly for only about 1 minute before they stop firing again because of black buildup on them again.
i replaced the wires, plugs, and distributor and am still having the same problem. timing is dead on. any ideas???????
Old Jul 16, 2002 | 07:26 AM
SpooN Man's Avatar
Default Re: b16 is in....cylinders #2 and #4 getting no spark (red civic standard)
injectors stuck open ??? **** I hope everything is ok. It does sound like a fuel issue. like the injectors are just dumping fuel in and running really rich in 2 and 4. Did you doubble check you injector wiring.
[Modified by SpooN Man, 1:07 PM 7/16/2002]
Old Jul 16, 2002 | 07:44 AM
EF_LSVtec's Avatar
Default Re: b16 is in....cylinders #2 and #4 getting no spark (SpooN Man)
try swapping 1 and 3 injector plugs with 2 and 4...if you get same results then injectors bad.
Old Jul 16, 2002 | 12:55 PM
crxjdmsir's Avatar
Default Re: b16 is in....cylinders #2 and #4 getting no spark (EF_LSVtec)
Did you swap the wiring or are you still running Dual Point Injection wiring? If so that is your problem or you may have wired it incorrectly. Don't take offense just trying to help w/o knowing what has or has not been done. Also do you have the proper injector resistor box? Or as previously mentioned it may be bad injectors but unlikely. Good luck.
Old Jul 16, 2002 | 04:40 PM
Default Re: b16 is in....cylinders #2 and #4 getting no spark (crxjdmsir)
i did the wiring myself...but have done a dpfi to mpfi swap already in my other car. I just used the 2 dx injector wires for cylinders #1 and #3 and ran two new wires for cylinders #2 and #4. Also added in the injector resistor box.
I know that the cylinders are getting fuel (too much) because the plugs are super black. How could i know that the injectors are stuck open? Any other ideas?
b18cgsrturbo
Oct 29, 2015 05:07 AM
H22Ej1
11
Jul 26, 2009 10:16 PM
k20o2o4civic
Feb 6, 2008 12:18 AM
red civic standard
Jul 18, 2002 03:13 AM
red civic standard
Jul 16, 2002 05:18 PM
