OIL LEAK ???
Old May 27, 2008 | 08:13 PM
deadman2008's Avatar
Default OIL LEAK ???
i have a 93 honda accord lx 2.2 and it has a oil leak from the back of the motor its not comeing from the valve cover its leaking from between the oil filter and intake manifold only when its running i cant see exactly where its leaking from but in runs down a black line/pipe that runs from left to right along the back of the motor and the drips on the exhaust where could it be leaking from???
Old May 28, 2008 | 04:50 AM
Hobbs94's Avatar
Default Re: OIL LEAK ??? (deadman2008)
did u check the oil pressure sending unit it is right above the oil filter
Old May 28, 2008 | 06:12 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: OIL LEAK ??? (Hobbs94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hobbs94 &raquo;</TD></TR><TR><TD CLASS="quote">did u check the oil pressure sending unit it is right above the oil filter</TD></TR></TABLE>
x2
may just have to remove it, clean it, put hondabond on the threads and re-install.
Old May 30, 2008 | 08:07 PM
fleetw00d's Avatar
Default Re: OIL LEAK ??? (TouringAccord)
Unfortunately, it is more likely coming through the switch. If you're going to pull it out, they're cheap enough, install a new one.
joelmatt89
Jul 16, 2011 01:30 PM
mani_0130
Mar 1, 2009 08:36 AM
Tim Martin
Feb 18, 2006 01:06 PM
Mike banX
Oct 9, 2004 09:24 PM
People_Mover
May 19, 2003 01:05 PM
