Civic with GSR question
How do you know if ur IAB or dual butterfly solenoid works? can u really feel a jump in power once it opens up after vtec??? if u have a gsr manifold do you really need to wire it to the ecu? well I wired it but I dont know if it works or not..
well I would like to keep everything stock and run the motor the way it was intended to but on a civic chasis.. then in the near future ill upgrade the manifold..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raidacaipo »</TD></TR><TR><TD CLASS="quote">comon jeezer heads.. help a brotha out
listen to the man
</TD></TR></TABLE>listen to the man
I'm telling you. There a pain in the ***. You will be doing yourself a favor. I have taken them out of several motors and always thought it felt smoother.
yea i got a skunk 2 manifold aswell.. i didnt want to fu^& with the iab. but i just get a blox theres not much differences at all... i wish i would of knew that when i got mine i would of save atleast $100.nows the time to get a hondata intake gasket
You dont have to get a new intake mani. All you need to do is remove the bolts that hold that cap on there and pull the butterflys out. Put the cap back on with some honda bond and shorter bolts.
562daybid
16
May 8, 2008 03:29 PM
Ex-Eg-Driver
Nov 26, 2006 08:09 PM
jaydm ferio
Nov 22, 2004 12:44 AM
