PLEASE HELP CAR WONT START
Old May 27, 2008 | 07:17 PM
sjbmx's Avatar
Default PLEASE HELP CAR WONT START
so my car wont start. i took it to a shop and they said it was the starter, they fixed it. it started and i drove homethen i got home and they same problem. all the lights and stuff come on but it dosent even turn over and when the key isnt in the igniton it makes a clicking noise like the turn signal is on. please help me
Old May 27, 2008 | 07:21 PM
LoseRPunKx182's Avatar
Default Re: PLEASE HELP CAR WONT START (sjbmx)
is the click from under the steering wheel? what year? i would check the main relay first and tap it a couple times. it might be on its way out.
Old May 27, 2008 | 07:24 PM
kelviiv's Avatar
check the ignition fuse
Old May 27, 2008 | 08:58 PM
DAtegLs's Avatar
Default Re: PLEASE HELP CAR WONT START (LoseRPunKx182)
well even if you take the main relay completely out it will still turn over it just wont catch. like he said though either tap the relay or just knee the underside of the dash. that works for me every once in a while...and my main relay's half dead.
Old May 27, 2008 | 09:21 PM
sjbmx's Avatar
its a 97 ls, the click is from a alarm and if i pop the clutch it runs fine
Old May 27, 2008 | 09:23 PM
johnls's Avatar
Default Re: PLEASE HELP CAR WONT START (DAtegLs)
damn are all integra wanted to stop working mine started doing the samething going to check it out in the morning i hear a click but its not starting sometime if i let the clutch out and push it back in may start hope its just relay
Old May 27, 2008 | 09:45 PM
sjbmx's Avatar
i just dont want it to be serious. you dont think its serious right?
Old May 28, 2008 | 08:08 AM
sjbmx's Avatar
hahahhaha i had a remote starter kill i didnt know about...dont i feel stupid
Old May 29, 2008 | 06:04 AM
Professor X's Avatar
Check the ground on the thermostat housing. I have had this problem before. I completely replaced the main relay and when that didn't fix it, I found that I had left the ground bolts loose. HTH.
Old May 30, 2008 | 06:27 PM
johnls's Avatar
Default Re: (Professor X)
damn im still having the problem put a new relay in still same thing no blow fuses my problem is when i go to start the car sometimes it starts than other time i get a click but if i let the clutch out a lil bit it may start but only sometimes it works anyone got any ideas
4doorpowa
24
Jan 24, 2023 04:36 PM
DaiSeeFut
Oct 31, 2012 04:51 PM
ILUVTEC
Mar 20, 2010 01:30 PM
Rukusmasta2
13
Feb 7, 2006 07:11 AM
BlackDiamond
Aug 16, 2005 02:08 PM
