?????piston information?????
Old Jul 15, 2002 | 09:41 PM
rainmanEK's Avatar
big strong guy
Default ?????piston information?????
Does anyone have experince with the "IMPORT BUILDERS IB SPEC WISECO PISTON"?
Are these lighter then stock itr pistons?
Would the forged design be ok for daily driving? piston slap, etc....
I am currently rebuilding gsr bottom-end and would like to use the gsr rods, will the pistons be able to be pressed on like stock ones? i am asking becasue i noticed most forged pistons have those clips that hold wrist pins in?
Would you recomend that i stay with maybe, jdm itr piston and mill head? I would prefer ~mid to high 11 compression ratio?
Any other recomendations? Advice?
much thanks,
eric
Old Jul 15, 2002 | 09:52 PM
Drag R's Avatar
Default Re: ?????piston information????? (rainmanEK)
I Doubt your gonna get any feed back for a while, There Pistons are going in my ITR Block, I'm using Eagle Rods, so i have my old ITR Rods if your interested. They only have 11,xxx miles on it. Let me know $200
Nick
I'll gove you feed back as soon as i get mine back
Old Jul 15, 2002 | 09:58 PM
tonyxcom's Avatar
Default Re: ?????piston information????? (Top Fuel ITR)
YOU need to use aftermarket rods with wiseco pistons. Almost all aftermarket pistons are full floating design.
Please correct me if I am wrong.
Old Jul 15, 2002 | 10:00 PM
rainmanEK's Avatar
big strong guy
thanks, though i have gsr rods that are in the bottom-end now! Though i do have question? Why did you choose Jeffs Weisco pistons over say, endyne or JE? i plan on choosing by end of week, so i can rebuild underway!
thanks, eric
Old Jul 15, 2002 | 11:38 PM
Toda Party's Avatar
I believe they're cut a bit deeper to allow some more piston-valve clearance ... i think.
Old Jul 16, 2002 | 02:53 AM
rainmanEK's Avatar
big strong guy
Default Re: ?????piston information????? (Toda Party)
could someone varify, if these pistons or any forged pistons could be used with stock gsr rods? thanks, eric
Old Jul 16, 2002 | 04:01 AM
Tbone's Avatar
Yes , you will have to bush the rods(have bushings pressed in) then you can free float them and use the little c clips.
Old Jul 16, 2002 | 04:40 AM
MiraiZ's Avatar
I'm not sure if they are "lighter" than ITR's, but the Endyn's are light as a feather!
Old Jul 16, 2002 | 09:34 AM
pinota's Avatar
Default Re: ?????piston information????? (MiraiZ)
I got 1 week ago the wiseco piston kit and eagle rods for my ITR.
See the pics here:
http://foto.sapo.pt/ver_fotos.asp?al...12142855420469
Old Jul 16, 2002 | 01:46 PM
rainmanEK's Avatar
big strong guy
Default Re: ?????piston information????? (pinota)
i belive endyne pistons weigh more then the "import builders" weisco's and je pistons! this is why i have left them out of perspective! thanks, eric
[Modified by rainmanEK, 11:06 PM 7/16/2002]
Old Jul 16, 2002 | 01:53 PM
Reid's Avatar
Global Moderator
i belive endyne pistons are weigh more then "import builders" weisco's and je pistons! this is why i have left them out of perspective! thanks, eric
Weigh or way?
The ENDYN pistons are among the cheapest aftermarket pistons you can buy.
I'm sure the weight difference between all of them isn't that significant also.
Old Jul 16, 2002 | 02:29 PM
non-VTEC's Avatar
Default Re: ?????piston information????? (Reid)
i doubt any forged aluminium pistons will weigh less than the stock cast pistons.......cast B18C5 pistons are pretty damn light......but forged aluminium is so much stonger.......
Old Jul 16, 2002 | 06:32 PM
ImportReview
Guest
Posts: n/a
They are lighter than the Endyn parts. Those are some of the heaviest pistons out. Heavier than mine, heavier than JE.
And Mine are cheaper than the Endyn pieces.
I will beat ANY endyn piston price. Show me a quote, I beat it.
IB Spec were designed to be the most advanced piston on the commercial market. They are as trick as you would expect.
Wiseco makes Rollerwave, Wiseco makes IB Spec.
Except mine are designed for you all in mind. Deeper valve reliefs, without using larger domes. Because they don't have the huge slice cut out of the valve pocket area in between, like Rollerwave, we can achieve even more compression without sacrificing effeciency, while making it SAFER to run larger cams.
+ the skirt design is more S2000 territory, than the old style Endyn skirts.
And yes, both have anti-detonation rings, and oil grooves in the pin area.
These are simply state of the art, Honda Pistons. And for the price of the Group buy going on right now, you will be very satisfied with them.
Best Buy forum.
IB
Old Jul 16, 2002 | 08:09 PM
rainmanEK's Avatar
big strong guy
Default Re: ?????piston information????? (ImportReview)
Thanks everyone! Jeff you will be getting call later this week! eric
Old Jul 16, 2002 | 08:44 PM
ITR21's Avatar
u dont need forged pistons for an all motor setup
Old Jul 17, 2002 | 07:33 PM
Drag R's Avatar
Default Re: ?????piston information????? (ITR21)
daysi guess reliability means nothing now a days....
Old Jul 17, 2002 | 07:37 PM
Big Phat R's Avatar
Default Re: ?????piston information????? (non-VTEC)
not true
Old Jul 17, 2002 | 09:06 PM
t's Avatar
t
[Modified by t, 10:13 PM 7/17/2002]
Old Jul 17, 2002 | 09:10 PM
t's Avatar
t
Post the weights of your pistons.
Wouldnt you want larger domes for more compression?
gsr96cx
Nov 17, 2007 07:45 PM
vtec.dc2
Sep 23, 2003 04:55 PM
LSVTEC408
Nov 20, 2002 02:20 PM
ic108
Feb 7, 2002 09:46 PM
SteelCityKid
Jan 10, 2002 12:08 PM
