GSR SWAP into 96 civic
Old May 27, 2008 | 06:54 PM
36Chitownrunnin's Avatar
Default GSR SWAP into 96 civic
I just installed a 01 gsr(b18c1) in to my 96 civic hatch cx.Stock harness still in with a p72 ecu 96 integra gsr. I still have the engine harness from 01 gsr which is a obd2b i believe. So my question is what sensor's do I need to pin into the ecu?
Old May 27, 2008 | 07:14 PM
raidacaipo's Avatar
Default Re: GSR SWAP into 96 civic (36Chitownrunnin)
you need the knock sensor, the vtec solenoid and vtec pressure switch (jdm doesnt need a vtec pressure switch if you have ecu) and the IAB (dual butterfly) from your manifold.. then u gotta make the conversions for the IAT plugs, you gotta cut it and take the round plugs and retro fit it. The IACV plug has to be modified too.. since the stock harness has 3 wires, the gsr has 2 so you need to cut the orange one and retro fit the 2 wires..
Old May 27, 2008 | 07:44 PM
geebs's Avatar
Default Re: GSR SWAP into 96 civic (raidacaipo)
check this page.. it has a great guide to swapping in a b series vtec engine to ek dx chassis.. http://technet.ff-squad.com/
Old Jun 17, 2022 | 08:28 AM
Eddybetts's Avatar
okay what about on the 98 Lx chasie..with its stock harness...
Old Jun 17, 2022 | 08:53 AM
spAdam's Avatar
Loved
Community Favorite
Everything you want to know is in the stickies at the top of this forum. No need to necro bump 14 year old threads.
jezzy
Aug 11, 2014 02:40 PM
MadCoder
Jan 12, 2013 10:15 AM
Sp00nFed EM1
29
Feb 11, 2008 04:58 AM
blkb18
Mar 9, 2006 10:13 PM
