loose cam gear bolts = valve contact?
Old May 27, 2008 | 06:12 PM
mkw1's Avatar
Default loose cam gear bolts = valve contact?
moved my car in the driveway and just started to hear a taping noise shut it off on the spot and investigated and found out my all my cam gear bolts loosend up causing the exhaust gear to switch timing. the gear says +15 or -15on each end .so im wondering if it moves all the way in either direction will the valves contact the piston causing the taping noise or maybe i was hearing the gear jerking back and fourth. i set the gear correct and car sounds fine but now im worried about the valves
Old May 27, 2008 | 08:33 PM
projectTeG's Avatar
thats a large possibility, find out why the slipped.
do a compression test
i would just take the head off to inspect the valves.
Old May 28, 2008 | 02:29 AM
Garrett's Avatar
if you don't hit the vtec
your are lucky
Old May 28, 2008 | 09:35 AM
mkw1's Avatar
Default Re: loose cam gear bolts = valve contact? (mkw1)
i just got this motor back together and was moving the car out of the garage so the car never went aver 2000 rpm the clicking noise only happened about 10 times before i got the car turned off .there was no lock tight on the exhast cam bolts thats why they came loose.
92civicx
Jul 16, 2009 05:37 PM
DB1_559
Jan 14, 2007 10:00 AM
balbowskie187
Apr 24, 2005 10:08 PM
ZEMX3
Feb 22, 2005 06:31 AM
