Dans garage sale, B series Motor/Mounts/Axles/ECU's+More!!! Turbo!
Old May 27, 2008 | 05:56 PM
Dasfinc's Avatar
Default Dans garage sale, B series Motor/Mounts/Axles/ECU's+More!!! Turbo!
I'll post up pictures later on, but I have the following forsale: (Local pickup is assumed or buyer can pay shipping) I'm located in Ottawa IL, 61350
I'm paypal verified and have several vouches on here and honda tech as well as hondaswap
1994 B18A1/B1 FULL AND COMPLETE long block (A1 block, 94 stamped B1 head) with an UDP on the alternator and a 6 puck clutch with PP and flywheel all still on the motor - $400
*In corner of shed, bad picture but it gets the point across*
Full B-series Mount set, Upper and lower, including brackets (poly insert not included)- $125
94-01 Axles and Midshaft - $100
*All of the above items $450 picked up, all you'd need is a trans and shift linkage and you'll be good to go*
OBD1 P75 ECU - $60
OBD0 P75 ECU - $40
GSR Header - $60
OBD2a Automatic LS ECU - $25
Resistor box *for use with the DSM injectors - $15
D-series rear T-bracket - $15
D-series CX/VX transmission with bad main bearing *still drove and shifted fine, ust made noise* - $30
2 OBD1 Civic engine wiring harnesses *cut* - If you need any connectors with cabling, let me know, probably only $5 shipped for any connector with wires
Home made EF/ED Intake - $30
14B/TD05 Mitsu Turbo - $140
B-series Hydro trans starter $40
95 Hydrolic LS Transmission Innards (Gears/forks/syncros/diff) - $150 shipped, Pulled from working transmission with ZERO grinds, shifted WONDERFULLY, the original Differential let go and cracked the case, I bought a replacement Diff before finding out the case was wrecked,
Feel free to call me at 630-857-6625, or email me at Dasfinc@hotmail.com
Modified by Dasfinc at 6:34 PM 6/10/2008
Old May 28, 2008 | 06:31 AM
Dasfinc's Avatar
Default Re: Dans garage sale, B series Motor/Mounts/Axles/ECU's+More!!! Turbo! (Dasfinc)
Back to the top!
Old May 28, 2008 | 11:35 AM
Dasfinc's Avatar
LOTS o stuff!
Old May 28, 2008 | 02:49 PM
Dasfinc's Avatar
TTT
Old May 29, 2008 | 06:24 AM
Dasfinc's Avatar
morning bump
Old May 29, 2008 | 11:57 AM
Dasfinc's Avatar
mid day bump
Old Jun 3, 2008 | 10:42 PM
Shartek's Avatar
pm'd
Old Jun 3, 2008 | 10:53 PM
Dasfinc's Avatar
Default Re: Dans garage sale, B series Motor/Mounts/Axles/ECU's+More!!! Turbo! (Shartek)
Replied
Old Jun 4, 2008 | 11:32 AM
Dasfinc's Avatar
HUGE price drop on motor swap, only $550 picked up, come and get it!
Old Jun 5, 2008 | 07:46 AM
Dasfinc's Avatar
Back to the top!
Old Jun 8, 2008 | 08:18 PM
Sean5826's Avatar
how many miles on the motor?? block and head
Old Jun 9, 2008 | 06:13 AM
Dasfinc's Avatar
Default Re: Dans garage sale, B series Motor/Mounts/Axles/ECU's+More!!! Turbo! (Sean5826)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean5826 &raquo;</TD></TR><TR><TD CLASS="quote">how many miles on the motor?? block and head</TD></TR></TABLE>
PM'ed!
Old Jun 9, 2008 | 04:19 PM
Dasfinc's Avatar
Back to the top!
Old Jun 10, 2008 | 05:34 PM
Dasfinc's Avatar
Too the top!!!
ek9 citrus
Northwest (Sales)
Feb 11, 2010 07:08 PM
Dasfinc
Jun 14, 2008 11:36 AM
H22T94
Jun 25, 2004 05:02 PM
Austinbionic316
Feb 5, 2004 08:47 AM
