valve train upgrade?
Old May 27, 2008 | 05:11 PM
sjbmx's Avatar
Default valve train upgrade?
ok so ive got a 97 ls with 122,000 miles. id like to get to upgrade my valve train to some stage 2 cams, gears and springs and retainers all ive got now is an intake and coilovers. what can i expect for this? is this something i should even do? what else should i do while im down there? any sugestions on where/what to get? any help would be appriceited.
Old May 28, 2008 | 10:41 PM
sjbmx's Avatar
Default Re: valve train upgrade? (sjbmx)
*** on...........
Old May 29, 2008 | 02:34 AM
Dark@Powers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjbmx &raquo;</TD></TR><TR><TD CLASS="quote">ok so ive got a 97 ls with 122,000 miles. id like to get to upgrade my valve train to some stage 2 cams, gears and springs and retainers all ive got now is an intake and coilovers. what can i expect for this? is this something i should even do? what else should i do while im down there? any sugestions on where/what to get? any help would be appriceited.</TD></TR></TABLE>
Stage 2 cams on an internally stock engine is not right. Stage 2 cams, for any company, generally RECCOMEND an increase in compression and increased flow at both the intake and exhaust ports of the head.
You're going to want a lot of things which you probably have not even figured into your budget yet, have you set a power goal? On top of this, your car is somewhat entering the "high mileage" category and you might want to go ahead and rebuild the head since you're going to be working on it.
Look at some of the cam dyno's on http://www.skunk2.com
You might also want to read up on cams: http://www.team-integra.net/se...ID=51
A power goal can really help in allowing people to assess your situation.
Old May 29, 2008 | 08:15 AM
jomama's Avatar
eesh, it sounds like you've got some major questions to ask yourself (what are my goals, etc. like ^ suggested)) and some serious homework. ever consider a ls-turbo or ls-vtec?
Old May 29, 2008 | 12:07 PM
sjbmx's Avatar
im trying to to get about 200whp on a na or if i do ls-turbo mabye 250whp ish i want to turbo but i dont want to spend $2500
xtegb16x
Dec 1, 2005 06:59 PM
redlseg
Jun 27, 2005 06:53 AM
grenthang
Mar 13, 2005 11:57 AM
Im-Gay
Aug 16, 2004 06:08 PM
.honda.
Mar 22, 2003 05:03 PM
