Car wont past 2 step rev point
I purchased a ecu from phearable.net and I got it tuned months ago the car rauns great its just that now sometimes I cant rev past 3300 rpms which is where my two step is set at. To be honest the ish is annoying and I would like to find out what can possibly be the problem,and also sometimes my speedometer get stuck at zero and move up and down while im driving.
get another speedo cable. the spring inside the speedo cable broke and I was hitting my 2 step at 4k rpm on the interstate . went to junkyard got another one problem solve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlakeJ53 »</TD></TR><TR><TD CLASS="quote">I am interested too. I am having the same problem except I have a crx running obd1 with a mechanical speed sensor.</TD></TR></TABLE>
If your speedo is still working then it's not the cable, it's the speedo unit inside the gauge cluster. You'd have to replace the gauge cluster in this case.
WVHondaHatch
Jul 19, 2007 12:41 PM
