h22a4 transmission swap to h23 tranmission
hey guys i was at the track sunday and i broke the speed sensor mount right off the case. ive been looking for a new tranny but have had no luck until my buddy told me that his friend had a h23 tranmission alot of guys tell me that i will be able to swap them pretty easy without any problems but none of them has ever attempted this job if any of you guys can give me some advise that would be great. the only thing i no is the h23 has different gearing but iam also curious about the mounts and electrical and also the shift cables i guess what im asking will it be a direct swap or will it take some modification
would you suggest using this tranny or sticking with the h22 just need somebodys opinon and have you done this swap before also will i be able to use the same clutch and flywheel that is in my h22a4 tranny
its a turbo but i just found a h22 tranny for 50 dollars but i just took mine out today and im going to transfer all my stuff into that one since nothing happened to the gears but once again thanks honda tech for the support
fit, h22, h22a, h22a4, h23, honda, interchange, interchangeable, mount, problems, swap, tranny, transmission, weak
