Lock cylinder rod...
go to a honda-dealership and tell them what your looking for.. they will bring up a schematic with each part numbered.. you look and point they order you buy done
are you talking about the locks on the door? disable that ****, and get an alarm with a keyless entry. Did the same and its already done its job....they cant pick the lock or use any key to bend the lock open.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsyke »</TD></TR><TR><TD CLASS="quote">are you talking about the locks on the door? disable that ****, and get an alarm with a keyless entry. Did the same and its already done its job....they cant pick the lock or use any key to bend the lock open.</TD></TR></TABLE>
Yeah I took apart the passenger door panel to see if the rod was there and it was. The passenger side door was broken into...surprised my drivers side was missing the rod and not my passenger.
Decided I will most likely go for keyless entry if it doesn't involve the lock cylinders.
And like you said...no one can try and steal my sh*t.
I need to find a place that can install and alarm for my car...5speed. =o
You could try and DIY, just take it slow and wire it up real good. Check suspended hatches writeups, or sti killers.
Unfortunatly the locks do nothing, since you can bypass them. Hondas have the WEAKEST locks ive even seen. I had a civic that I could open with any key on my keychain.
triple beam
Jan 13, 2019 04:40 AM
