Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Stock 17inch tires...
Old May 27, 2008 | 09:27 AM
07siftw's Avatar
Default Stock 17inch tires...
I have to get new tires beccause the two fronts are SLICKS...
i only have about 19k on the car i dont do hardly any burnouts...
What was the mileage at which you replaced the stock tires???
Old May 27, 2008 | 10:57 AM
Nighthawk R18's Avatar
Default Re: Stock 17inch tires... (07siftw)
i guess you dont rotate your tires?
Old May 27, 2008 | 11:46 AM
a1staecksauce's Avatar
From: Westminster/Huntington Beach/Seal Beach, CA, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07siftw &raquo;</TD></TR><TR><TD CLASS="quote">I have to get new tires beccause the two fronts are SLICKS...
What was the mileage at which you replaced the stock tires???</TD></TR></TABLE>
so if you don't do hardly any burnouts then that must mean you do a lot of burnouts right.
haha jk, but ya, rotating your tires would help.
Old May 27, 2008 | 03:30 PM
dh's Avatar
dh
Default Re: Stock 17inch tires... (a1staecksauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">i guess you dont rotate your tires? </TD></TR></TABLE>
Sounds like it
Old May 27, 2008 | 03:40 PM
i-VTEC_DOHC's Avatar
well at his point its pointless to rotate the tires.
cuz if ur gonna put slicks in the back, your f***ed if it rains. and he stands a higher chance of a blowout since there is more negative camber in the rear than in the front.
Old May 27, 2008 | 04:20 PM
jdimi34's Avatar
I had the same issue. I had rotated my tires twice and still had to replace them around 15k. I think the snow and ice may have played a part in my quick tire wear.
Old May 27, 2008 | 04:43 PM
well it actually depends on which tires you got with your car. with the all seasons or the summer tires which are michelin pilots. im at about 8.7 k and i already rotated my tires once.
Old May 27, 2008 | 08:49 PM
Blackknight103's Avatar
if you have access to a lift daily, it wouldnt be a bad thing to rotate ur tires more often. I use a lift at my school autoshop and just by having that available, i can rotate them every 5 or 6k miles. Only take 15 minz tops so why not do it more often
Old May 27, 2008 | 08:50 PM
07galaxygrey4dr's Avatar
i had to constantly rotate mine, but they still were gone by 30,000. the camber in the rear of the car seems bad. i have an si though, so i guess i couldn't have the same camber problem that the other models have...
Old May 28, 2008 | 12:58 PM
93civicjaydm's Avatar
Default Re: (07galaxygrey4dr)
i got 16,000miles out my 2 fronts with 24 runs at the track. i did rotate them tho, i do need to get 2 more for the rear tho.
Old Jun 2, 2008 | 07:08 PM
ohdannyboy73's Avatar
I live in climate without snow and put new tires on at 38000. Believe it or not they they still had tread left.
FA All Day
50
Dec 24, 2007 08:21 PM
CRISIS
Jun 28, 2006 08:46 PM
BoBoChan
10
Oct 12, 2005 01:10 PM
SeOuLxK
Honda Motorcycles
32
Feb 24, 2005 08:10 PM
RUBZERK
Feb 4, 2004 10:15 PM
