Adding Air Conditioning
Old Jul 15, 2002 | 08:37 PM
Overdrive440's Avatar
Default Adding Air Conditioning
How hard is it to add A/C to a 1991 Civic DX? What's involved with this and is it fairly simple? Too hot here to live without A/C!
Old Jul 15, 2002 | 09:37 PM
bryant's Avatar
Default Re: Adding Air Conditioning (Overdrive440)
I dont know about adding it to one that was never equiped in the first place. but if yours alreaddy had it and your just looking for the parts. check my sig.
Old Jul 15, 2002 | 09:50 PM
Sgt_Ox's Avatar
If it never had A/C to begin with then you'll need the housing for the evaporator since non A/C equipped Civic's/CRX's had a a generic hosing that was used for the blower. Then there's all the usual parts for hte A/C as well.
Old Jul 16, 2002 | 11:11 AM
Car has no A/C. So basically take everything from an A/C car, and put it in? No holes to cut for the housing, or anything??... Sounds pretty straightforward then. Wiring and the like should be simple too. I'm sure a good service manual should show msot of the details.
Old Jul 16, 2002 | 11:58 AM
civicwagonman's Avatar
everything will swap in real easy. done it to two cars already. the wiring is already int he dash for the button, and the other wirign harness unplugs under the dash right where the ac box goes, and from the fusebox on the pass side fender.
Sanford727
Oct 17, 2010 02:52 PM
.john.
Welding / Fabrication
13
May 14, 2010 05:02 PM
liljestrand
Mar 6, 2007 07:15 PM
EclipticX
21
Apr 30, 2004 08:45 PM
