Valve adjustment?
Old May 27, 2008 | 06:26 AM
Pman92's Avatar
Default Valve adjustment?
Hi all. Just recently redid the top end on My H23. Running KMS dual Race Springs and Chromoly Retainers with Crower Turbo Cams. New stock Size valve on intake and exhaust. There is alot of valve chater when you first start the engine up untill it warms up then the noise seems to be normal. We have adjusted them 3 different time now and doesnt seem to change anything at all. Anyone else running into this or am I just overlooking something. Any help would be appreciated.
Old May 27, 2008 | 06:34 AM
Jagan'92's Avatar
Default Re: Valve adjustment? (Pman92)
the valves do chatter loud, compared to other cars. what clearances did you use? I just set mine again yesterday, to .003" in and .006"ex
Old May 27, 2008 | 06:45 AM
Pman92's Avatar
Default Re: Valve adjustment? (Jagan'92)
well used the specs that came with the cams its .006 and .008. cant remeber witch is the intake or exhaust spec. A friend of mine that has been building honda engine for boost for a while readjusted them for me again.
Old May 27, 2008 | 06:46 AM
Pman92's Avatar
your running those cleareances on stock cams or aftermarket? I know stock clearance on my car is .007 and .009.
Old May 27, 2008 | 07:28 AM
Jagan'92's Avatar
i'm running those clearances on stock cams. i used the helms for the specs (h23) and put them on the tight side. i thought .007"IN was the F22 engine specs. maybe i should double check.
ref-> https://honda-tech.com/zerothread?id=986295
Modified by Jagan'92 at 11:35 AM 5/27/2008
Old May 27, 2008 | 09:56 AM
98vtec's Avatar
moderator emeritus
use the cam spec cards recommendation.
also, is there are a reason you decided to run KMS valvetrain and not the appropriate crower valvetrain?
if you are getting valve chatter, then the specs are too loose.
Old May 27, 2008 | 07:29 PM
vlang29's Avatar
make sure the engine has cooled overnight before doing the adjustment
Old May 27, 2008 | 10:34 PM
TruNinja619's Avatar
Default Re: Valve adjustment? (vlang29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">make sure the engine has cooled overnight before doing the adjustment</TD></TR></TABLE>
+1. Thats the best time to adjust valves.
Old May 28, 2008 | 05:49 AM
vlang29's Avatar
Default Re: Valve adjustment? (TruNinja619)
it is absolutely required that it be dead cold when you adjust the valve lash. As soon as the engine is warmed at all, the metal expands and reduces the clearances. So if it is set to proper spec when the engine is warm, they will be much too loose when cold. Heat expansion is the only reason we have to adjust the valves to the specified clearance, if metal never expanded, we could run basically no clearance without a valve sticking open
Old May 29, 2008 | 05:58 AM
Pman92's Avatar
Yes we did set the clearances when the engine was cold and yes we did use the specs that came with the cams. everything was adjusted before the car was even started. We set the clearances alittle tighter than normal. The reason on the KMS springs and retainers was just trying to stay in my budget area.
Old Jun 11, 2008 | 08:52 AM
4WSi_guy's Avatar
stock specs are Intake .004-.005in and Exhaust .006-.007in... got that from Mitchell on demand.
Old Jun 12, 2008 | 07:42 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pman92 &raquo;</TD></TR><TR><TD CLASS="quote">There is alot of valve chater when you first start the engine up untill it warms up then the noise seems to be normal.</TD></TR></TABLE>
This sounds like piston slap. Valve lash actually increases as the head warms up.
Old Jun 13, 2008 | 07:53 AM
JT's Avatar
JT
Default Re: Valve adjustment? (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">
This sounds like piston slap. Valve lash actually increases as the head warms up.</TD></TR></TABLE>
I'm sorry but I have to disagree. I've never seen valve lash clearance increases when the engine is warmed up. It has always been my experience that the clearance gets tighter when the engine is warmed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlang29 &raquo;</TD></TR><TR><TD CLASS="quote">it is absolutely required that it be dead cold when you adjust the valve lash. As soon as the engine is warmed at all, the metal expands and reduces the clearances. So if it is set to proper spec when the engine is warm, they will be much too loose when cold. Heat expansion is the only reason we have to adjust the valves to the specified clearance, if metal never expanded, we could run basically no clearance without a valve sticking open</TD></TR></TABLE>
Old Jun 13, 2008 | 08:57 AM
mgags7's Avatar
Different rates of expansion for the valves and the rockers?
Old Jun 13, 2008 | 07:43 PM
bluedlude's Avatar
Default Re: Valve adjustment? (mgags7)
he never said anything about running different valves, just the springs and retainers. if all is within spec, call it a day. just hope you picked a good combo.
uvamosk
29
Mar 8, 2012 02:12 AM
exownzu
Sep 30, 2006 08:58 AM
dc5r2002
Jun 16, 2004 03:41 AM
Doc_Honda
Oct 22, 2003 08:55 AM
baddboy
Mar 18, 2003 08:30 AM
