Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Should I use inverted tie rod ends on my 2002 Acura EL?
Old May 26, 2008 | 08:59 PM
EL-Driver's Avatar
Default FAQ got my confused about Tie Rods to use on my 02 Civic 4DR
Hi there....
just finishing up my Civic 4DR EX (SOHC VTEC motor) DD
all that is left is the suspension, so this is what has been done:
Lowering springs + Tokico D-Spec shocks = 1.9 Drop front & Rear
Replaced upper and lower ball joints
Running 15's for now on 205/55/15
now last thing to do before sending it to the alignment shop is the Tie Rods.
I read the FAQ and it says inverted Tie Rods can be found on the EP3 civic aka 03+ Civic Si I believe
but confused are these bolt-on or do I have to more so I can run these?
any advantage to them?
or
at the drop I am at, is it better to run the application suited for my car?
Thank you
Old May 26, 2008 | 09:06 PM
toyomatt84's Avatar
Sanji
Default Got my confused about Tie Rods to use on my 02 Civic 4DR (EL-Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL-Driver &raquo;</TD></TR><TR><TD CLASS="quote">Lowering springs + Tokico D-Spec shocks = 1.9 Drop front & Rear
or
Thank you </TD></TR></TABLE>
Well, first of all, you don't have an "Upper ball joint" on your car. You have a MacPherson setup, which lacks those.
Secondly, with that drop, you won't necessarily NEED inverted tie rod ends unless you plan on tracking the car heavily. After about 2" of drop, I'd say it'd be a wise investment. They're designed to prevent bump steer, and do quite well on track applications. (PS. They're not a Honda offered product, they're aftermarket.)
jayj99crv
Honda CR-V & Element
Nov 27, 2018 11:50 PM
DAP97SI
Suspension & Brakes
20
Jun 27, 2007 08:06 AM
da_33
Jan 25, 2007 07:20 PM
zerospooon
33
Mar 6, 2002 04:11 PM
Adampops
Jan 15, 2002 10:54 AM
