99-00 tranny problems
Old May 26, 2008 | 08:53 PM
b16_swap's Avatar
Default 99-00 tranny problems
okay so i have a tranny that wont go into gear, unless the car is off. It also moves when i let off the clutch and no gas is given. It also wont let me out of gear once it is in gear. one of many problems. it makes a funny rumbling noise when i turn the car. any ideas on what to do??
Old May 27, 2008 | 08:18 AM
wmac's Avatar
sounds like you clutch is not completely dis-engaging. check clutch fluid first, or shift linkage might be screwed up.
it would be good to know what car you are talking about.
Old May 28, 2008 | 11:58 AM
b16_swap's Avatar
Default Re: (wmac)
my clutch isn't slipping when i try reversse it makes a screeching noise
Old May 28, 2008 | 12:35 PM
Professor X's Avatar
Did you recently change the clutch or flywheel? It sounds like the disc may be backwards.
Old May 28, 2008 | 02:13 PM
b16_swap's Avatar
Default Re: (Professor X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Professor X &raquo;</TD></TR><TR><TD CLASS="quote">Did you recently change the clutch or flywheel? It sounds like the disc may be backwards.</TD></TR></TABLE>
hmm i havent touched the inside of the tranny since i did my swap, umm, any other suggestions?? besides disc being on backwords
Old May 28, 2008 | 02:19 PM
Jimmy's Avatar
Global Moderator
Default Re: (b16_swap)
Typically when the car is hard to go in gear i would first recommend checking your clutch reservoir.. Make sure it is full..
It could also be a sign of a bad/leaking clutch master cylinder.
If not.. Top it off, try bleeding it using the 8mm nut on the slave cylinder..
Also crawl under your dash and up where the clutch pedal is.. and check to see if you see any fluid leaking or wet/dampness.. If so it's time to replace the clutch master cylinder..
If all of this checks out okay.. I would lean more towards a failing clutch disk/pressure plate.
Old May 28, 2008 | 02:22 PM
b16_swap's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Typically when the car is hard to go in gear i would first recommend checking your clutch reservoir.. Make sure it is full..
If all of this checks out okay.. I would lean more towards a failing clutch disk/pressure plate.</TD></TR></TABLE>
iite man i'll give it a try, thanks for the heads up
Old May 28, 2008 | 09:44 PM
Mista Bone's Avatar
D Tranny Guru
B series clutch disc has spit a spring.
Very common B series failure.
futurefastguy
Oct 13, 2006 10:32 AM
816d16
14
Nov 16, 2005 08:26 AM
LSeeper
May 12, 2004 08:15 PM
civicnightmare
21
Feb 7, 2004 12:00 AM
