99-00 tranny problems
okay so i have a tranny that wont go into gear, unless the car is off. It also moves when i let off the clutch and no gas is given. It also wont let me out of gear once it is in gear. one of many problems. it makes a funny rumbling noise when i turn the car. any ideas on what to do??
sounds like you clutch is not completely dis-engaging. check clutch fluid first, or shift linkage might be screwed up.
it would be good to know what car you are talking about.
Re: (Professor X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Professor X »</TD></TR><TR><TD CLASS="quote">Did you recently change the clutch or flywheel? It sounds like the disc may be backwards.</TD></TR></TABLE>
hmm i havent touched the inside of the tranny since i did my swap, umm, any other suggestions?? besides disc being on backwords
Global Moderator
Re: (b16_swap)
Typically when the car is hard to go in gear i would first recommend checking your clutch reservoir.. Make sure it is full..
It could also be a sign of a bad/leaking clutch master cylinder.
If not.. Top it off, try bleeding it using the 8mm nut on the slave cylinder..
Also crawl under your dash and up where the clutch pedal is.. and check to see if you see any fluid leaking or wet/dampness.. If so it's time to replace the clutch master cylinder..
If all of this checks out okay.. I would lean more towards a failing clutch disk/pressure plate.
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Typically when the car is hard to go in gear i would first recommend checking your clutch reservoir.. Make sure it is full..
If all of this checks out okay.. I would lean more towards a failing clutch disk/pressure plate.</TD></TR></TABLE>
iite man i'll give it a try, thanks for the heads up
futurefastguy
10-13-2006 10:32 AM
816d16
14
11-16-2005 08:26 AM
dunkd
06-27-2005 09:05 PM
civicnightmare
21
02-07-2004 12:00 AM
