GSR brake setup in an EG
okay so i decided to go bigger brake setup on my EG but dont know exactly what parts i need to take off of the gsr for it to work on my EG.. if anyone out there knows of the parts i need any info will help for the front i know i need the calipers and the rotors the rear i know i need the complete rear disc converstion right is there anything that i need for my suspension left??? any info will help thanks HT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpvw »</TD></TR><TR><TD CLASS="quote">SEARCH</TD></TR></TABLE>
did that already didnt find much
when I did mine I got the whole hub/knuckles for the front and the whole trailing arm assembly for the back along with the ebrake cables (uncut). Then I bought a 93 integra 4040 proportioning valve. You prob won't need it but I bought an integra brake booster and a 1" brake master cylinder. The 1" MBC are harder to find and more expensive, I would recommend at least a 15/16 MBC and the integra brake booster for a firmer pedal feel and less travel. Otherwise the rest should fit, ie front upper/lower control arm, rear LCA etc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sorrule »</TD></TR><TR><TD CLASS="quote">when I did mine I got the whole hub/knuckles for the front and the whole trailing arm assembly for the back along with the ebrake cables (uncut). Then I bought a 93 integra 4040 proportioning valve. You prob won't need it but I bought an integra brake booster and a 1" brake master cylinder. The 1" MBC are harder to find and more expensive, I would recommend at least a 15/16 MBC and the integra brake booster for a firmer pedal feel and less travel. Otherwise the rest should fit, ie front upper/lower control arm, rear LCA etc</TD></TR></TABLE>
^^^ hes got everything right. im about to do the same thing with my civic. how is the 1" master cylinder working for you? pretty good brakes?
thanx
for the info guys
thanx
for the info guys
