Which Spark Plugs: NGK BKR7EIX-11 or BKR6EIX-11
Old May 26, 2008 | 03:46 PM
92integraVTECgsr's Avatar
Default Which Spark Plugs: NGK BKR7EIX-11 or BKR6EIX-11
Got a question. I've finished building my LS/VTEC and came across something interesting about spark plugs.
I am using a 2001 ITR Head with a B18a1 Block with OS P30's so about 11.5-12.0:1 Compression.
I am searching NGK's site for 2001 Integra Type R spark plugs and they have the Iridiums listed : BKR7EIX-11. But then I search 2000 Integra Type R & GS-R and they both came up BKR6EIX-11.
I know the difference between the 6 and 7 is heat range, but I don't know which one is colder or hotter.
Which one would be better for my setup? I am thinking to just use the BKR7EIX-11 from the 01 ITR since the ITR motors are higher compression.
Old May 26, 2008 | 03:58 PM
Default Re: Which Spark Plugs: NGK BKR7EIX-11 or BKR6EIX-11 (92integraVTECgsr)
I just read on NGK's site that the higher the number, the colder the plug.
Old May 26, 2008 | 04:12 PM
b19coupe's Avatar
7s
Old May 26, 2008 | 06:08 PM
TheShodan's Avatar
Moderator
BKR7EIX-11 Stock #2667
Old May 26, 2008 | 07:27 PM
dr.garagetuner's Avatar
the 6 is hotter and the 7 is a colder plug
http://www.ngksparkplugs.com/d...y.pdf
Old May 26, 2008 | 07:29 PM
Default Re: (dr.garagetuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr.garagetuner &raquo;</TD></TR><TR><TD CLASS="quote">the 6 is hotter and the 7 is a colder plug
http://www.ngksparkplugs.com/d...y.pdf</TD></TR></TABLE>
Ya I already figured that out. Thanks.
Old May 26, 2008 | 08:34 PM
killerpenguin21's Avatar
Default Re: (92integraVTECgsr)
7's all the way.
i ran 8's on the dyno and my tuner said they were too cold. still made 196 tho!
Old May 27, 2008 | 02:38 AM
Garrett's Avatar
you don't need iridium
SeanK325
Nov 3, 2010 08:32 AM
123Four
Sep 22, 2007 03:28 PM
1sikhatch
Feb 25, 2007 02:51 PM
90TT
Nov 25, 2004 08:45 AM
silvercivicsir
Feb 18, 2002 02:36 AM
