help! o2 sensor disconnect, dunno order to reconnect the wires.
Old Jul 15, 2002 | 07:54 PM
zojirushi's Avatar
Default help! o2 sensor disconnect, dunno order to reconnect the wires.
this is for a 95 integra ls. The wires popped off the connector, and i need the wiring scheme for it. Thanks.
Old Jul 16, 2002 | 07:44 AM
zojirushi's Avatar
Default Re: help! o2 sensor disconnect, dunno order to reconnect the wires. (zojirushi)
TTT the sooner someone can help me, the sooner i can finish my turbo intstall, thanks
Old Jul 16, 2002 | 11:38 AM
stick's Avatar
dont know if LS is diff from GSR but:
top of clip
G w
B B
of course G is for green
W is white
and B is for black
hope this helps
Old Jul 16, 2002 | 12:38 PM
Mr. Softee's Avatar
Default Re: help! o2 sensor disconnect, dunno order to reconnect the wires. (stick)
pretend the o2 sensor is coming out of hte cat. there are 4 wires coming out of it that go up to a clip.
can someone tell me how those wires go into the clip?
Old Jul 16, 2002 | 03:34 PM
stick's Avatar
Default Re: help! o2 sensor disconnect, dunno order to reconnect the wires. (94goldjungsr)
read my above post
that should work
Old Jul 16, 2002 | 04:12 PM
Jamison's Avatar
same thing happened to me. just keep putting the wires into the clip until the check engine light goes off. it took me 5 times then i got it.
Old Jul 16, 2002 | 07:32 PM
zojirushi's Avatar
stick, i owe u big time, thanks a bunch
Old Aug 6, 2002 | 09:01 AM
delacampos's Avatar
hate to bring this back but the pattern above isn't working for my 97 gsr. are the green and white wires closer to the firewall or front bumper?
if i were standing at the front of the car, looking down, is this the pattern
G W
B B
or
B B
W G
do the black wires make a difference as to what place they go in?
any help is appreciated. thanks!
[Modified by delacampos, 6:03 PM 8/6/2002]
Old Nov 18, 2002 | 09:00 AM
IntegraGSR23's Avatar
Default Re: help! o2 sensor disconnect, dunno order to reconnect the wires. (delacampos)
Anyone here know the proper and correct sequence for this?
If anyone can help, it is greatly appreciated.
BTW this is for a 1996 GS-R
[Modified by IntegraGSR23, 10:00 AM 11/18/2002]
Old Nov 18, 2002 | 09:04 AM
metal-x's Avatar
Default Re: help! o2 sensor disconnect, dunno order to reconnect the wires. (IntegraGSR23)
this is off my 95 gsr
Old Nov 18, 2002 | 09:17 AM
shadowdawn's Avatar
Default Re: help! o2 sensor disconnect, dunno order to reconnect the wires. (metal-x)
Will, thats funny that happened to you, ever since I moved my wideband to the first bung in my dp and the stock on about 1" down this happened to me, finally I just unclipped the harness from the bracket and let it sit freely with all the play it wants to it doesn't do that again
Old Nov 18, 2002 | 09:31 AM
Default Re: help! o2 sensor disconnect, dunno order to reconnect the wires. (shadowdawn)
metal-x: Do you happen to have any other views/angles of that?
Thanks
Old Nov 18, 2002 | 09:39 AM
Or if you could tell me the colors and sequence from the perspective pictured above?
Thanks
godluvstegs
Dec 15, 2010 07:08 PM
Jintegragsr97
May 27, 2007 12:48 PM
runitup
May 2, 2004 10:02 PM
pregunta
May 30, 2003 09:35 AM
SMC Integra
May 20, 2003 06:31 PM
