Need help fas please ! ...
Old May 26, 2008 | 10:43 AM
CALIGUYCRX's Avatar
Default Need help fas please ! ...
I have a 98 ex civic with a d16y8 , it blew up , so i got a 99 d16y8 an put i in , and while putting it in the only difference i ran into was the "idle air" has a 3 wire sensor instead of a two wire , so my question would be , can i swap my 98 d16y8 manifold onto the 99 d16y8 an have it work ? ? ?
Old May 26, 2008 | 10:52 AM
h22civic88's Avatar
Default Re: Need help fas please ! ... (CALIGUYCRX)
Why dont you just swap out the IACV's? Should bolt up the same...
Old May 26, 2008 | 11:21 AM
CALIGUYCRX's Avatar
Cuz the manifold i have is off a automatic just found out
Old May 26, 2008 | 11:29 AM
h22civic88's Avatar
Default Re: (CALIGUYCRX)
on your new motor? are you talking about the plug on the harness? Cause if you're using your old harness, just swap over the IACV
Old May 26, 2008 | 11:38 AM
CivicSpoon's Avatar
Yes, just swap manifolds.
Old May 26, 2008 | 11:39 AM
CALIGUYCRX's Avatar
There is not way to swap the IACV cuz of the auto manifold thats on the engine now . . . the 99 auto d16y8 uses a three wire , an mine is only a two wire ?
Old May 26, 2008 | 12:04 PM
h22civic88's Avatar
Yes, but you sould be able to botl up the manual one to the manifold... At least thats how it was on my Z6 cause I had to do that when I had it, and I certainly didnt have to change the whole manifold, but feel free to if you wanna wont hurt nothin
titi_vtec
Jun 29, 2010 05:07 PM
MilanoRed_EJ8
Mar 8, 2007 10:29 AM
Civic Racer X 7
Jan 15, 2006 09:38 AM
Devilry
Jul 16, 2005 09:38 PM
