car won't start all of the sudden
Old May 26, 2008 | 09:48 AM
fastcrvi's Avatar
Default car won't start all of the sudden
fuel is there, theres 12v at starter, it clicks when i get to III but doesn't crank at all, theres absolutely no ignition going even if i rollstart it.
battery is fine, all fuses are fine.
any suggestions on what to check?
this is 97 ls
Old May 26, 2008 | 12:47 PM
jonnybadboi9's Avatar
Default Re: car won't start all of the sudden (fastcrvi)
take off your distributor and get multimeter and test the two ignition coil posts.
The primary and secondary have specific specifications its suppose to be in between...
even if one of them is off by just a little bit... your car wont start.
Meaning, you need a new ignition coil.
While the dizzy is off though you can check the rotor, dizzy cap and also the icm.
Let us know the progress...
Old May 27, 2008 | 06:19 PM
fastcrvi's Avatar
Default Re: car won't start all of the sudden (jonnybadboi9)
will do that test.. but will that car still turn with bad ignition coil? cause it doesn't turn or crank at all..
Old May 27, 2008 | 06:47 PM
gsrcolt's Avatar
ya i pulled my teg in and changed the oil and done a compression test, after all was complete, i went to start it and there was nothing... it was the coil
Old May 28, 2008 | 08:05 AM
x3kevin's Avatar
Default Re: car won't start all of the sudden (gsrcolt)
my was the dizzy modual
Old May 28, 2008 | 11:34 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: car won't start all of the sudden (x3kevin)
mine was the ICM... guy on ebay sells them mad cheap... $40 or so... instead of $100+ at autozone... if u need one just PM me... ill give u his info
Old May 28, 2008 | 12:41 PM
Professor X's Avatar
Will it run if you roll start it? Is it 5 speed or auto? At first it sounds like the starter if it won't turn over when you turn the key and just clicks once. However, if your neutral safety switch/clutch safety switch is bad it might not allow it to turn over.
Old May 29, 2008 | 12:14 PM
jwrape's Avatar
Default Re: (Professor X)
Mine did that same thing.
I just replaced the plugs and rotor and cap. When i replace the cap I found the entire Dizzy cap and rotor was covered in dust. It was obvious it wasn't tuned up in a long time( I have only had the car for 2 weeks).
I started it up and it ran good after. Then I went to move the car later that night and it started and died. Then wouldn't start again. I tested out the coil and the ohms were too low. I replace the coil and it started right up
Old May 29, 2008 | 01:55 PM
fastcrvi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Professor X &raquo;</TD></TR><TR><TD CLASS="quote">Will it run if you roll start it? Is it 5 speed or auto? At first it sounds like the starter if it won't turn over when you turn the key and just clicks once. However, if your neutral safety switch/clutch safety switch is bad it might not allow it to turn over.</TD></TR></TABLE>
thats the problem, it won't run even if i do it from a roll.. seems like theres no ignition.. haven't had the chance to test coil yet
Old May 29, 2008 | 01:57 PM
Jimmy's Avatar
Global Moderator
Specifications for the coil and the ICM (ignitor) are in this thread below:
https://honda-tech.com/zerothread/2306055
Old May 30, 2008 | 04:38 AM
S2KILLA's Avatar
Default Re: (jwrape)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwrape &raquo;</TD></TR><TR><TD CLASS="quote">Mine did that same thing.
I started it up and it ran good after. Then I went to move the car later that night and it started and died. Then wouldn't start again. I tested out the coil and the ohms were too low. I replace the coil and it started right up</TD></TR></TABLE>
same [freak]ing thing happened to me as well... i had to change the coil and the ICM...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Specifications for the coil and the ICM (ignitor) are in this thread below:
https://honda-tech.com/zerothread/2306055</TD></TR></TABLE>
good link...
Old Jun 25, 2008 | 10:11 AM
fastcrvi's Avatar
Default Re: (S2KILLA)
replace distributor, waiste of money.. still won't start.. any ideas??? i can hear starter relay click one time but nothing happens as far as turning..
Old Jun 25, 2008 | 02:46 PM
fastcrvi's Avatar
Default Re: (fastcrvi)
loose starter wire.
Old Jun 25, 2008 | 02:50 PM
B18IntegraLS's Avatar
Reject Pimp
Get it fixed up? crvi
nitroice40
Mar 13, 2022 11:27 AM
C-West Civic
Jun 6, 2017 05:40 PM
teg your it
Aug 23, 2010 03:01 PM
em2ssm02
Jul 23, 2007 06:27 PM
RoaringTurtle
Jan 30, 2002 10:50 PM
