suspension guuru's chime in, need help with type r 4x114 and spoon coilovers
Old May 26, 2008 | 09:46 AM
jdm_AE86's Avatar
Default suspension guuru's chime in, need help with type r 4x114 and spoon coilovers
ok., ive been searching but cant get an "exact" asnwer. I bought 4x114 suspensiion that came with spoon n1 coils. now ive heard that rears will fit without mod, but, i wanna put AFTERMARKET LCA'S. ive also heard that eg lcas will fit but heres my question, with the type r susp on, does this still apply, can i buy aftermarket lca's for either eg or ef and have it still fit with the susp and the coils(which is made for integra??) In a nutsell i wanna upgrade some suspension stuff, just dont know that when i buy stuff(sway bars, lcas, uca's etc), will they work with the ef chassis+4x114 susp)
Old May 27, 2008 | 07:43 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (jdm_AE86)
Ok, so let me get this straight, you are installing the 4x114 suspension and are asking what after market LCAs will fit?
for what it's worth they arn't worth it really, but i'm pretty sure they should fit I've never done it with my own 2 hands so I won't say it will but part numbers for control arms *aftermarket* show up as 88-95 civic and 90-01 teg. So logically they will.
Old May 27, 2008 | 09:16 AM
jdm_AE86's Avatar
ya exactly, but will it be proper, with everything liing up and bolting up properly including the shocks?
Old May 27, 2008 | 11:36 AM
1989CivicSi's Avatar
Do you have the 88 style rear shocks or the 89-91 style rear shocks?
Old May 27, 2008 | 03:32 PM
jdm_AE86's Avatar
89-91, so can i get aftermarket lca's made for the 88 civic/crx and will they fit properly on my model (90 si) like these ones for example:
dont forget im using all integra R suspension with integra shocks
Modified by jdm_AE86 at 4:41 PM 5/27/2008
Modified by jdm_AE86 at 4:42 PM 5/27/2008
Old May 27, 2008 | 04:43 PM
beana's Avatar
Default Re: suspension guuru's chime in, need help with type r 4x114 and spoon coilovers (jdm_AE86)
go with accord wheels they're 4x114 but make sure the offset is at least 40mm(i think)
to make sure they fit
Old May 28, 2008 | 10:51 AM
Smokinsax's Avatar
The Boot
Default Re: suspension guuru's chime in, need help with type r 4x114 and spoon coilovers (beana)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beana &raquo;</TD></TR><TR><TD CLASS="quote">go with accord wheels they're 4x114 but make sure the offset is at least 40mm(i think)
to make sure they fit</TD></TR></TABLE>
FTW!!!
random *** statement...
I can't say for sure that the coils will work, but I do know that the 4x114.3 front knuckles and rear trailing arms all bolted up. I just used my stock crx LCA's and they worked fine, so if EG LCA's work on EF chassis then I don't see why not...
Stick with EF chassis specific sway bars....
I bought and used EF aftermarket front adjustable UCA's with the 4x114.3 knuckles
Old May 28, 2008 | 04:06 PM
jdm_AE86's Avatar
cool well then looks like ill just stick with EF related suspension ****, pretty sure if i use 88 lca's itll work with the type r shocks, thanks all,
if anyone else wants to put in their 2 cents, still greatly appreciated
Old May 28, 2008 | 04:19 PM
ONE-CAM-EF's Avatar
just get the aftermarket lca's for a ef dude..it will bolt right up...
Old May 28, 2008 | 05:04 PM
Patty's Avatar
Default Re: (ONE-CAM-EF)
i'm doing the same suspension set up (Spoon ITR) on my CRX when my tein's bite it. what front forks are you using.? I already got a set of EK forks but..... and how low can you get?
Old May 28, 2008 | 08:10 PM
jdm_AE86's Avatar
Default Re: (Patty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Patty &raquo;</TD></TR><TR><TD CLASS="quote">i'm doing the same suspension set up (Spoon ITR) on my CRX when my tein's bite it. what front forks are you using.? I already got a set of EK forks but..... and how low can you get?</TD></TR></TABLE>
not sure about that but heres a link on how to do the 5lug swap but supposedly its the same as 4x114
http://technet.ff-squad.com/how-to/5lug.ef-da/
Mugzy909
Sep 1, 2008 10:29 AM
JRRR
Honda Fit
Apr 21, 2008 08:32 PM
mugenspoongsr
Suspension & Brakes
Oct 3, 2006 11:40 PM
supaman111
Jun 28, 2005 05:28 AM
92integ
Feb 17, 2003 04:55 PM
