CRX Fuel Rail and FPR options... what is available
Old May 26, 2008 | 12:15 AM
SINISTR's Avatar
Default CRX Fuel Rail and FPR options... what is available
hey guys.
im wandering if I can get advice - which aftermarket fuel rail like OBX, AEM etc etc - comes with a FPR (fuel pressure reg) either built in or with adaptors?
as some may recall - i've installed the HKS charger onto my ZC motor - unfortunatelly the HKS fuel rail which would allow me to use my OEM regulator has been lost somewhere before i got the kit, so im using a bit of a home made setup...
Im wandering if anyone can recommend a fuel rail which either a) has a reg built on b) uses a side mounted FPR onto the rail or c) provides an angled adaptor to fit stock OEM fuel rail?
you can see where the FPR is atm, and i could move it to the firewall but i don't have much room for the FPR - its quiet big...
so looking for alternatives...
thanks
Mike
Old May 26, 2008 | 06:44 AM
zccr-xsi's Avatar
u really dont need to change out the fuel rail OEM rails can handle up to 500 hp.most people change them for a bling factor.
Old May 26, 2008 | 04:50 PM
SINISTR's Avatar
Default Re: (zccr-xsi)
oh yeah i don't want it for that - i only want to get the FPR in the right place....
Old May 27, 2008 | 06:28 AM
zccr-xsi's Avatar
Default Re: (SINISTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINISTR &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah i don't want it for that - i only want to get the FPR in the right place.... </TD></TR></TABLE>
well u can use a bm FPR they sit where the stock one does,and ive had zero problems out of mine in 3 years
Old May 27, 2008 | 07:29 AM
JRTegman987's Avatar
i was going to use the B&M regulator too...
but in the past two weeks i have had two friends have theirs **** out on them, one had been on the car for a week the other had been on the car for 2 years
it turned me away from them im probably going BDL
Old May 27, 2008 | 09:31 PM
SINISTR's Avatar
im using the stock rail and still have the stock FPR - however the supercharger actually forbids me from installing that back onto the stock position because of the bottom pipe and it hits the SC - if i can get a rail that will lift the FPR a bit higher to clear the SC i'd be happy...
that angled pipe when the FPR is fitted hits the SC underneath it...
i figured I need a 45 degree fitting to bolt onto my stock rail... and then the honda OEM FPR can go onto that...
any ideas?
Modified by SINISTR at 11:00 PM 5/27/2008
Old May 27, 2008 | 10:52 PM
SINISTR's Avatar
or i need something like this:
where would i get something like that?? - the adaptor to fit the FPR to the end of the rail?
Old May 28, 2008 | 09:15 AM
zccr-xsi's Avatar
have u caleed jr and told them your problem?u might need to bolck off the stock fpr hole and go with a fire wall mounted one.
and yea ive had friends use the b&m fpr AND HAD TO GO BAD.BUT MINE WORKS LIKE IT SHOULD.
Old May 28, 2008 | 04:33 PM
SINISTR's Avatar
the thing is its not a JR Supercharger - its a HKS one so its not something they are likely to be interested in helping me with.... im looking for an aftermarket or a custom solution if possible.
Old Jun 4, 2008 | 12:21 AM
SINISTR's Avatar
Anyone???
Bump....
drSquish
Feb 22, 2006 06:35 PM
racekar711
Nov 22, 2005 12:13 PM
mister2racer
Apr 16, 2004 03:56 PM
ITRfaithful
Nov 1, 2003 01:36 AM
