lowering springs for 97 crv
eibach!
back in the philippines,weve
tried fitting an odessey's spring in the
gen1 crv, ride still good considering its
always loaded with5-6 passenger as a daily
commuter..
commuter..
Has anyone experienced differential issues with their 1st gen CRV after lowering it? Im talking more than 1.5" drop for a long period of time 20K miles or more? Im leaning towards the H&R Spring kit as I have not found any one with the Eibach kit still available. I have even called Eibach directly and they dont even list thats as an application anymore as far as the 1st gen. Full Coilovers are out of the question on a daily driver.
it might just be your diff. fluid acting up for an oil change,LOL!
check out my V, i posted pics here..
im using HnR's as my daily suspension, but i hacked it a bit
to further more lowering my V..
no my old links were froze up so had to get new ones, and i used the d brackets and bushing that cam with just had to modify them a bit. the d brackets are a tight fit
found a seller who can do Spax CRV1 springs for 138 notes... thats my next purchase, along with a 4 way alignment.. 40mm drop is about perfect i think on 16" with decent profile
well the biggest problem i have is the struts bottoming out. i have 2/3 of the rubber bump stop cut out and still they bottom out and it bounces. ive been pulling parts and comparing at work thinking maybe i can use civic struts cause they are shorter. problem im thinking is that the weight difference between a V and a civic. maybe good civic struts would work but i dont want to pay alot for a test strut...lol
bump!!
ive used civic struts for 330mi. i too got worried
about the weight issues, idk how much more our
Vs weighs more compared to a civic, even if loaded..
ive used showa and sheepdog springs(old set) that was first
originally for my EG, as a spare its still on a diferent set.
i felt that the struts couldnt take it or maybe its just me,LOL!
i wouldnt suggest it for a daily, im tempted to buy those replaced(but still good)
oem shock/struts from an upgraded civic but still couldnt find one..
let us know if you happen to do it..
on the bushings?? to fit the bigger sway bars?
