rdx swap???
Old May 25, 2008 | 09:37 PM
vtecb18c's Avatar
Default rdx swap???
has anyone heard of anyone swapping a rdx engine in an eg or ek? i dont really know much about the rdx but being the first turbocharged factory honda i would think someone would try something
Old May 25, 2008 | 09:47 PM
BlueIntegraBoy's Avatar
Default Re: rdx swap??? (vtecb18c)
It simply won't fit like any other k-series engine...
Old May 25, 2008 | 09:54 PM
EvoMperor's Avatar
is that a top mount? what would be the size difference minus the top? interesting.
Old May 25, 2008 | 09:56 PM
lluks_844's Avatar
Default Re: (EvoMperor)
Wow, that looks crazy. I wanna try it lol to bad I cant even afford a k swap
Old May 25, 2008 | 10:02 PM
Default Re: (lluks_844)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Why It Won't Work &raquo;</TD></TR><TR><TD CLASS="quote">1) iVTEC only on the intake side
2) Intake cam has two lobes instead of three
3) Completely different mounts that any other K-series. (Not a bolt in)
4) The block is quite a bit larger than exsisting K-series (clearance issues)
5) All belt driven accessories mounted towards front of the block. Every Si owner knows how short our engine compartments are.
6) Does not bolt up to exsisting K-series transmissions. Uses a version of the RL tranny which is quite large and heavy. (Honda claims the stock K-series trannies are not strong enough to hold all the torque) (May not be totally true since there are plenty of turboed RSX's with over 260 lbs tq)
7) Connecting rod bolts are M8 where as other K-series use M9 (only a problem if you want more power)
8) Stock turbo is limited to 13.5 psi (must upgrade turbo if you want more power)
9) Top mount intercooler makes the engine very tall
10) Good luck getting the ECU to interface with our car</TD></TR></TABLE>
Old May 25, 2008 | 10:09 PM
blkegcoupe's Avatar
From: ....................................................................................................
Default Re: (BlueIntegraBoy)
It can work just a little ingenuainility and a fat wallet if i had time and a motor like that yeah i would attempt it mostly for the hell of it and yeah it would suck if it was in but the motor couldn't run cause of the ecu but i'd ghetto rig it in a way to make it work..
Old May 25, 2008 | 11:26 PM
wholios-EG's Avatar
Default Re: (blkegcoupe)
i wish i had the bank for lol
Old May 26, 2008 | 12:45 AM
-JAWSHUA-'s Avatar
thatd be pretty crazy.
Old May 26, 2008 | 01:04 AM
mizzoEG's Avatar
Default Re: (-JAWSHUA-)
An RDX swap is just too unlikely considering all the statements that BlueIntegraBoy listed above. Even if it was somehow or someway possible, imagine the amount of labor, money, precise examination and customizing that would need to be done to do a swap that only puts out a factory tuned 240hp/260tq. and if you were planning on building the motor, then whats the whole point? just get yourself a regular K and call it a day.
Old May 26, 2008 | 03:57 AM
gibsanez's Avatar
Default Re: (mizzoEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mizzoEG &raquo;</TD></TR><TR><TD CLASS="quote">An RDX swap is just too unlikely considering all the statements that BlueIntegraBoy listed above. Even if it was somehow or someway possible, imagine the amount of labor, money, precise examination and customizing that would need to be done to do a swap that only puts out a factory tuned 240hp/260tq. and if you were planning on building the motor, then whats the whole point? just get yourself a regular K and call it a day. </TD></TR></TABLE>
It would make more sense to just built and boost a K instead of dumping money just to MAKE the K23 engine fit.
Old May 26, 2008 | 07:14 AM
blkegcoupe's Avatar
Default Re: (gibsanez)
thats loser talk if we all went like that the world wouldn't be what it is today all we need is someone to possible the impossible and thats someone who's gangsta enough to do it well..at least with a piggy bank
Old May 26, 2008 | 07:43 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkegcoupe &raquo;</TD></TR><TR><TD CLASS="quote">thats loser talk if we all went like that the world wouldn't be what it is today all we need is someone to possible the impossible and thats someone who's gangsta enough to do it well..at least with a piggy bank </TD></TR></TABLE>
you're preaching to the converted. A lot of people think the H2B in an 88-91 civic is impractical but I did it anyways.
Did you even read any of the points that were mentioned earlier? The engine isn't even THAT great, it's just the fact that it's a factory boosted K. It just doesn't seem worth it. Maybe just to say I have an RDX engine. It reminds me of the F2K.
"1) iVTEC only on the intake side
10)<U>Good luck getting the ECU to interface with our car</u>"
Old May 26, 2008 | 08:08 AM
k0shi's Avatar
well im sure if someone could put a LS1 in a ek like the civette or like how that other guy made his own mounts and other parts to put that boosted rotor engine it must be possible to do this swap, but like everyones sayin u should just got boosted k lol
Old May 26, 2008 | 08:57 AM
gibsanez's Avatar
Default Re: (k0shi)
Obviously nothing's impossible, it just wouldn't really be worth it. It doesn't have any clear price/power advantage over boosting a K on your own.
Old May 26, 2008 | 10:22 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Obviously nothing's impossible, it just wouldn't really be worth it. It doesn't have any clear price/power advantage over boosting a K on your own.</TD></TR></TABLE>
My thoughts exactly. For the hassle and expense of swapping in the RDX engine with an inferior tiny turbo, why not just swap a stock K20 and boost it. There's a lot more potential in the latter option without all the previously mentioned obstacles of the RDX swap.
skill178
Oct 28, 2011 12:36 PM
nomoshing
Nov 20, 2009 04:00 PM
highflyin250x
Apr 19, 2007 01:35 PM
EG_Civic_Si
91
Sep 27, 2004 08:22 PM
