92 civic h22a power steering vss bypass
hey there , i recently did an h22 swap in my buddies car i got the swap manual online that says how to do all the wiring and were to pin and so on . the only problem we ran into was the vehicle speed sensor is kinda odd . the motor is a jdm and has a power steering vehicle speed sensor . i was wondering if theres any way we can by pass this valve so we can get a reading ? thanks and let me know asap !! he needs his car !!
Just make a hose loop so it doesn't puke out what power steering fluid is left in there and so it won't dry out. The power steering connection has nothing to do with the speedo working or not working. Some DA Integras had this same thing; it's more like a pump to circulate power steering fluid through a cooler from what I understand. VSS will work as normal as long as something is not messed up.
Ryan
Ryan
well from what i read theres a valve in that vss that tells the car how fast ur going to give the proper power steering assist !! well do i have to push that volve open for it to work or what ?
