Wheel pulls under heavy braking or going through water
Old May 25, 2008 | 05:22 PM
musclehead954's Avatar
Default Wheel pulls under heavy braking or going through water
My steering wheel pulls really hard to the left (especially) and to the right when i brake hard or suddenly, and it has almost sent me into oncoming traffic on a few occaisions. the same thing happens when i go through a deep puddle. my alignment is off, due to rough roads at work and some ******* railroad tracks. does the pull come from my alignment or some other problem?
Old May 25, 2008 | 05:33 PM
vtecb18c's Avatar
Default Re: Wheel pulls under heavy braking or going through water (musclehead954)
yea it sounds like an alignment issue...if its pulling you into other lanes i would ge that done asap before you kill yourself
Old May 26, 2008 | 06:31 AM
Default Re: Wheel pulls under heavy braking or going through water (vtecb18c)
Bump
Old May 26, 2008 | 07:19 AM
forsakenriceboy86's Avatar
sounds like a alignment problem when its pulling and when your getting pulled when your braking, check your brakes(rotor for warpage).. also hows your tires.?!? tires, when the side wall are worn(on the inside) it tends to act like so too...
Old May 26, 2008 | 06:38 PM
Default Re: (forsakenriceboy86)
i think it may be the tires, bc my air pressure was really low for a while, but i only have 6,3xx miles on them. the rotors are ok. i think im going to take it to tire kingdom for an alignment check.
Old May 26, 2008 | 07:19 PM
iluvmy2000civicex's Avatar
Default Re: (musclehead954)
Yea if rotors arent warped just make sure you keep your tire pressure where it needs to be and get an alignment asap.
jmccalip
Apr 24, 2008 06:38 PM
mrdeadman
Jul 19, 2005 06:51 PM
GSblueRacing
Jul 6, 2002 10:47 PM
seano
Jun 2, 2002 01:14 PM
Seann
Jul 29, 2001 02:22 PM
