Engine service b18cr
I want to give my b18cr engine a good full service. So where do I start from?
the engine only done now nearly 90,000 Km's and its abit noisy now since nothing done to it yet!
thing Ive done: Changed the engine oil with new oil filter, new spark plugs. Now looking at getting some new spark plug leads.
So what other things these engines need when they get old?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ice2004 »</TD></TR><TR><TD CLASS="quote">I want to give my b18cr engine a good full service. So where do I start from?
What do you mean by its noisy? Sounds like maybe you need to do a valve adjustment. I do it it a few times a year. If I remember correctly if you rev over 8k its recommended. Do you have the original timming belt and oil pump?
What I mean is that the engine isnt running smooth as how it used to be.
You can hear everthing knocking maybe its the tappets not sure or valves?
Yes still got the original timing belt and oil pump.
have taken it over 8 couple times but no point when my peak power is 7800 or something. I found out when I had it on the Dyno.
How can I do the valve adjustment?
Is it expensive?
Is it expensive?
valve adjustment is what you need
replace pvc valve
replace dizzy cap/rotor
replace spark plug wires
replace engine oil/ tranny oil
replace timing belt/new tensioner
replace fuel filter
clean injectors
clean the throttle body
enjoy
replace pvc valve
replace fuel filter
clean injectors
enjoy
valve adjustment
tranny change
spark plug wires
fuel filter
cap/and rotor
coolant flush
timing belt&water pump (not a oil pump)
clean throttle body and a new air filter
and type r should be good to go
tranny change
spark plug wires
fuel filter
cap/and rotor
coolant flush
EG-SIXV-TEC
Dec 5, 2013 06:26 PM
