AC compressor wiring help....
Old May 25, 2008 | 02:53 PM
Grandhustleman86's Avatar
Default AC compressor wiring help....
I've owned my 92' cord for nearly 2 years now but the AC system was uninstalled by the last owner....I have absolutley everything for the reinstall:
1. Junkyard compressor (hope its good)
2. New Reciever/Dryer W/ Oriphus
3. New Seals (Green)
4. R-12 - R134a Retrofit kit
5. all hoses
6. Junkyard Condenser
7. AC Flush
8. shop will evacuate system
9. shop will Oil System
10. shop will fill system
Im currently stuck with the AC compressor right now because the connectors on the chassis for the system were cut by the previous owner....im in need of wire a wire diagram (from chassis to compressor) on this....it will be soldered and heatshrinked for temporary use....until I can get to a Pull-a-part for connectors.
Old May 25, 2008 | 03:22 PM
Default Re: AC compressor wiring help.... (Grandhustleman86)
here is a picture I've come across I belive the Red is the connector to the AC compressor but I have no Idea where the Blue and Black connector go....any input is helpful.
Old May 25, 2008 | 06:02 PM
im deeply in need of help here....FYI the vehicle is a 92' Accord DX.
Old May 26, 2008 | 07:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grandhustleman86 &raquo;</TD></TR><TR><TD CLASS="quote">Name:  CRXPROGRESSPICSAC.jpg
Size:  38.4 KB</TD></TR></TABLE>
these wires and connectors are down in the driverside front below the headlight....if that helps.
Old May 27, 2008 | 02:05 PM
After no help here I moved to mitchell and All-data and found that the Blue & Black is for the condenser fan....and the red is the power to the compressor clutch and it is grounded on itself hence the single wire connector.
RxRC
Honda CR-V & Element
Jun 27, 2016 10:23 PM
JohnnyEF
Jun 7, 2012 03:16 AM
c1civic
May 1, 2007 06:12 PM
Draggin99Si
Dec 29, 2006 05:36 PM
slow99gsr
Jul 16, 2006 03:04 PM
