transmission stuck to engine block
I'm trying to remove my transmission from my engine, d15b8, and it appears to be stuck to the engine block. I removed the five housing bolts... is there something that I am missing or is there a trick to get it unstuck? I tried beating it with a rubber mallet.. BTW, the engine is out of the car.
Anthony
Anthony
Lift up on the trans housing a little while beating so it comes off straight. It's going to take some wiggling to get it to come loose. I've even used pry bars in extreme cases, but be careful where you use them.
JohnnyB70
Aug 26, 2004 06:49 AM
97, block, civic, engine, honda, lifter, prelude, removing, stuck, tech, tranny, trans, transmission, transmissionstucktoengine, transmisson
