camber kit
Old May 25, 2008 | 10:59 AM
eglude's Avatar
Default camber kit
ok i bought some cheap rhino camber kits on ebay, now the ball joint on the passenger side is make noise. every little bump it makes noise as if it were loose. my question is, is there a way to fix that or do i have to replace it? if i have to replace it do i have to buy the whole thing again or can i just buy the ball joint? thx in advance
Old May 25, 2008 | 11:47 AM
elektronsi's Avatar
Default Re: camber kit (eglude)
you can buy the ball joint separately, if you can i would reccomend getting a skunk2 kit to replace the one you have, check the hondamarketplace im sure some1 has a set for cheap
Old May 25, 2008 | 06:32 PM
pimpvw's Avatar
Default Re: camber kit (elektronsi)
are you sure that the balljoint is bad or are they just loose
Old Jun 11, 2008 | 05:40 PM
PlayBoyT's Avatar
Default Re: camber kit (pimpvw)
the same exact thing just happened to mines, is it confirmed that the skunk2 ones will fit?
codyellis
Aug 5, 2009 08:12 AM
b18bc3po
Apr 2, 2009 11:18 AM
blbvtec
Jun 28, 2003 08:59 PM
Shorty C
14
Jun 15, 2003 09:23 AM
Warren
14
Jun 7, 2002 12:34 PM
