Need some help with power window wiring...
I'm converting my cx to power windows/locks and I need some help finishing the wiring.
I have uploaded pictures of everything I have wiring wise...
I have all of the wiring schematics but I want to see if anyone else out there has done a similar setup.
I have the entire door harness for both sides and the complete under dash harness from an ex plus a power window relay for the fuse box. There were some minor differences in a few connectors though so I just cut out the wiring harness that runs from the cabin to the pass door.
Can I just run power and grounds to these reaming wires to make this work?
Any help or suggestions is greatly appreciated!
I just took the connector from the main harness that plugs into the back of the fuse box and spliced all the wires that matched into the drivers side harness. Still no luck. I have the relay and all 3 20A fuses plugged into the fuse box also
I tested the connector at my driver side regulator and + going through all 4 wires... that can't be good
bmg123
17
Aug 15, 2011 08:27 PM
BigDaddyRich
Aug 22, 2002 11:09 AM
